Old Jun 19, 2022 | 03:23 PM
  #4801
Bee-Raddd's Avatar
It's time to re do my motor mounts as the cusco ones have been in for a few years now.
Looking for the hardest motor mount set on the market for the least engine movement i can get. Looking at torque solutions at the moment. any other brands to look at? (apart from cusco)
Old Jun 19, 2022 | 07:27 PM
  #4802
alpinaturbo's Avatar
Brad, don't know if Cusco are really hard, but when I had hard motor mount without balance shafts, it was an awful experience.
The roll-stopper is key in Evo to keep engine from moving, the side-motor/trans mounts indeed hold it but engine is not trying to move on them: it tries to rotate, thus roll-stoppers.
I like stock or maybe slightly stiffer main motor/trans mounts; perhaps Ralliart? That may be Cusco equivalent if Cusco is rubber.
Vibration that comes from solid motor mounts loosens bolts, and is really unpleasant. I cannot think of benefit to make up for it.
Cheers,
Old Jun 19, 2022 | 07:56 PM
  #4803
Bee-Raddd's Avatar
Cheers,
I have a roll stopper installed already. Main thing is it affects my shifting actuator for the paddleshift if i have too much engine movement
Old Jun 19, 2022 | 08:13 PM
  #4804
Dallas J's Avatar
Veteran: Army
TBH, I keep OEM side motor mounts because without balance shafts people are experiencing a lot of bolts backing out over time in critical areas. And I just havent seen the need to stiffen the side mounts.
Old Jun 19, 2022 | 08:24 PM
  #4805
ViciousLSD's Avatar
threw out my tran side torque solutions, thats firkin too much for my dashboard! lol
Old Jun 20, 2022 | 06:44 AM
  #4806
Ayoustin's Avatar
Any specific bolts? I have all 4 torque solutions mounts and never have had any bolts vibrate loose.
Old Jun 20, 2022 | 07:33 AM
  #4807
Dallas J's Avatar
Veteran: Army
Ive been lucky not to have anything major happen but I have had my water pump bolts back out. And I don't use loctite on those specifically cause its a PITA to get off as it is. But others have had crank pulley bolts loosen if seen as well. Aaron shoe lost a motor a few years ago when the center bolt loosened on him IIRC. Have also seen people claiming torqued and loctite flywheel bolts come loose which would really be crappy to fix.
Old Jun 20, 2022 | 11:55 AM
  #4808
Bee-Raddd's Avatar
I cant say ive ever experienced this and i have like 70 shur rubbers installed into my cusco mounts. But it loctite everything and torque mark so easy to pick up if things come loose.
Old Jun 21, 2022 | 08:53 AM
  #4809
LetsGetThisDone's Avatar
I also have not experienced bolt loosening due to BS deletes and poly side mounts.
Old Jun 21, 2022 | 02:09 PM
  #4810
Dallas J's Avatar
Veteran: Army
Bah, after axle boot leak last event I got that fixed and fired up the car today only to get the charge/brake light staying on. Wonder if the grease from axle worked its way into the alt maybe? Either way, gotta get something in a day or two. I might just pick up whatever local alt is available and rebuild mine or get an outlander to swap in if the part store one sucks.
Never a dull moment!
Old Jun 21, 2022 | 02:15 PM
  #4811
Balrok's Avatar
Is that what lucky dog ended up with?
Old Jun 21, 2022 | 02:25 PM
  #4812
Dallas J's Avatar
Veteran: Army
Yeah. It doesnt just drop into place though I still dont know what needed to be modded on it. Internet price for them are pretty good, $240ish for OEM unit.
Old Jun 21, 2022 | 02:41 PM
  #4813
ViciousLSD's Avatar
I have a 'tire sprayer' filled with concentrated degreaser for crap like that. check plugs tho, in case they got disconnected
Old Jun 21, 2022 | 05:10 PM
  #4814
jaytreble's Avatar
My summer todo list:
Replace Front Lower Control Arms
Install Coilovers
Replace Serpentine Belt
Fix AC
Hoping my AC is an easy fix because it's starting to get hot af here T_T
Old Jun 22, 2022 | 06:31 AM
  #4815
Kevin.'s Avatar
Install Coilovers
Fix AC
https://www.evolutionm.net/forums/ev...ega-guide.html
one of the best threads. Most commonly it's that damn clutch.
