Anyone coming to Solo Nats have a spare Left (driver) side rear axle as a back up? I think mine is on the outs and groaning a ton. Its pretty loud driving down the road at 65mph and you can definitely hear it when swerving right but it quiets turning left.
We did about 80 miles today in Utah site seeing with it on our long trip to Lincoln. Its the most street miles Ive seen in 4 years probably. And we have a few more places to drive so we'll see if the axle holds together.
also, I’ve had a bad bearing on the other side and you could easily feel it being bad. I’ll double check again but pretty sure it felt free last check.
I’ll get under the car after next drive and try to feel what is getting hot. I’m guessing the inner axle cup because it’s now leaking a little bit of fluid. Doesn’t for normal AX events but freeway driving seems to get the fluid liquid enough to seep out.
CVs (rzeppa joints) and tripods are a somewhat standardized deal so it we are lucky Mitsu didn't go making their own bespoke size and we should be able to get aftermarket joints, just a matter of measuring the stock ones. The harder parts to get (if they're damaged) would be the end housings for them.
thanks
