Old Jan 14, 2025 | 12:52 PM
  #6586
kyoo's Avatar
https://www.amazon.com/Atesilor-Wheel-Fitment-Tool-Materialand/dp/B0DLFD41YJ/ https://www.amazon.com/Atesilor-Wheel-Fitment-Tool-Materialand/dp/B0DLFD41YJ/
has anyone used something like this? Won't show tire fitment but curious how accurate it is.
Old Jan 14, 2025 | 01:09 PM
  #6587
ViciousLSD's Avatar
what in the world? have to remove the caliper looks like. probably wont tell you much. I dont get rubbing/contact when commuting even with cargo, but i've had rubbing during autox(no cargo). i've grinded this trailing arm 3x for example, lost sections of fender liners and side skirts.
Old Jan 14, 2025 | 05:43 PM
  #6588
211Ratsbud's Avatar
Originally Posted by Construct
That's an interesting point. If I was primarily instrumenting the turbo then having pressure sensors at the inlet and outlet would be ideal.
I'm interested in EMAP for Speed Density tuning. Using manifold pressure and temperature is realistically fine. I'd like to experiment with using EMAP to calculate the pressure ratio across the engine for estimating load. Having EMAP logged is also helpful for knowing when you're asking too much from a small turbo.
In theory a tune that uses IMAP and EMAP to calculate pressure ratio would be much more forgiving of changes on the exhaust side: Driving to different altitudes (different atmospheric pressure at exhaust exit), swapping a catted DP for a test pipe on track days, or even changing turbos. The easy method of tuning with IMAP and MAT assumes that everything on the exhaust side remains constant, including atmospheric pressure.
I found some old conversations on another forum where someone logged EMAP from the EGR port as well as at another location closer to the turbo. His EMAP measurement from the EGR port was noisier as I expected. It also read a couple psi lower. Could be as simple as measurement error from different sensors, but now I'm wondering if there is some venturi effect due to the EGR inlet location. The difference looked small enough.
I'd be using an EMAP damper stuffed with steel wool to dampen some of the noise, like this:
You can use emap:imap to control MIVEC.
I set this up in a v88 but never did anything with it.
Someone else should try it 🦝
Old Jan 15, 2025 | 09:15 AM
  #6589
Construct's Avatar
IMAP:EMAP pressure ratio can be used for load calculations in general. If implemented properly it should be more resilient to changes in anything after the exhaust port, such as swapping out exhaust pieces or changing altitudes (pressure at the exit exhaust).
mrfred and others discussed using EMAP for speed density patches a decade ago: https://www.evolutionm.net/forums/ec...lculation.html
Getting a good EMAP reading is part of the challenge. I picked up a Haltech which lets you average IMAP and EMAP readings across a configurable period. You can also add filter coefficients or a filter table based on RPM. Mechanically, EMAP sensors are connected through a long length of hose and an expansion/damper tank to average the pulses out.
Our twin-scroll setup adds another challenge because exhaust pulses are split. Maybe I'll try to get a look at the EMAP signal and try different averaging periods to see what it looks like.
Old Jan 18, 2025 | 08:04 AM
  #6590
kyoo's Avatar
well, 4th gear exploded while we were tuning the 71hta on e85, so i guess I'm gonna have to get a built 5 speed again...
Old Jan 18, 2025 | 08:42 AM
  #6591
LetsGetThisDone's Avatar
You have a 6 or 5 speed that 4th blew up in?
If going to a 5 speed, Evo9 ratios plus a 1:1 straight cut 4th gear drive really well. Pick final drive based on your expected torque. Stock for <500ftlbs, 4.31 for 500-750ish ftlbs, 4.11 for everything else.
Old Jan 18, 2025 | 08:47 AM
  #6592
kyoo's Avatar
6spd, freshly rebuilt by tre.
going to a 5spd, but staying final drive. just planning to stay around 400whp.
Old Jan 24, 2025 | 06:05 AM
  #6593
kyoo's Avatar
Apparently PPG makes a strengthened 4th gear for the 6 spd that TRE now stocks. Going to give it a shot
Old Jan 24, 2025 | 06:13 PM
  #6594
Meathooker's Avatar
interesting I hadn’t heard of that.
why all of the effort to stick with a 6 speed?
Old Jan 25, 2025 | 07:49 AM
  #6595
kyoo's Avatar
I just love the 6 speed. I've had the 5 speed, I've had the 5speed built with the "ultimate" gear ratios, but I just love the snick-snick feel of the 6. If PPG is still developing stuff for the Evo 9 MR, I want to give it a shot to support the development. I may buy a spare gear just to keep it on hand.
Old Jan 25, 2025 | 06:25 PM
  #6596
Meathooker's Avatar
I don’t think I’ve ever driven a 6 speed Evo (wexcept x shift and that doesn’t count) I always assumed they felt the same just one more gear. I’ll have to give it a try next time I come across one
Old Jan 25, 2025 | 08:53 PM
  #6597
The 6spd box shifts notably better. It is a much more refined transmission. If I were to have a "street" <450whp Evo I would want the 6 speed in it.
Old Jan 30, 2025 | 10:31 AM
  #6598
kyoo's Avatar
I'm a little late to the buzz but have any of you guys used Valvoline restore & protect? even BITOG seems to be relatively impressed by the oil, but I'm still trying to scour the webs to see how this will work. Thinking of using it for my 280k mi Sequoia, maybe my new-to-me Veloster N also.
Old Jan 30, 2025 | 03:15 PM
  #6599
kyoo's Avatar
Also, most aftermarket bolt on brake kits should fit with the SSB uprights, right? I know I had to grind the bracket a little bit for the ap racing mounting bracket fitment but if the dimensions are designed to be bolt on to stock it should fit the SSB uprights, yes?
Old Jan 31, 2025 | 10:28 AM
  #6600
Evo9isLife's Avatar
5 Year Member
Never used it before but its primary purpose is to clean a high mileage engine with less than ideal oil change intervals and its pretty good at it from what I've seen. From what I understand Valvoline claims to use some proprietary additive "PROPRIETARY SUBSTANCE OF HITEC 11188" that wont show up in an oil analysis, but it does have a good dose of detergents too. Its definitely lacking esters, zddp and moly for anti-wear though. Personally I would use a quart of HPL Engine Cleaner: HPL Engine Cleaner in your next oil change with oil that has better anti-wear properties.
