yea very good points, no arguments here. I guess the only thing I would say is that usually those sorts of things (stability, etc, etc, etc.) go hand in hand with increasing the size and mass of the rotors, though I see what you mean by the annulus area helping, among other things, it will be a better heat sink as well.
I'm on the tiny ap racing brakes right now with ~325mm rotors. It's been a decrease in braking force compared to the Evo 10 setup I used to run, but benefits in other ways of course. I guess I'm just hoping to capture some of that back without "braking" the bank.
Having said that, another good option is to have a disc as large as will fit into the wheel, and then have a small annulus. That way you still have a large disc, good disipation and just enoguh mass, but not too much. I have in my shop two front systems, both based on brembo grN calipers.. one is the grN system 355mm, large annulus... other one is a 370 mm, small annulus... 370 mm disc is actually signifficantly lighter... Now, not having tested them I am just making presumptions, but the 370 mm might be a better choice for the track, where speeds are higher than in rally and you can run wheels large enough...
edited in: it is not really about the force and lever... more about the capacity of the system to transform kinetic energy into heat and transfer it to the air without getting the main parts too hot which will result in friction coefficient to drop and the driver will feel it as loosing brake performance...
It doesn't make a huge difference in the calculations, but it's worth doing it right.
For braking performance and heat tolerance, the size of the pad is what matters. The annulus alone doesn't tell the whole story because the height and shape matter, too.
For a given rotor diameter, a larger annulus will have more thermal mass and area to dissipate heat, but also more weight.
8k f / 12k r
biggest WL rsb. uprights front and rear. we did some snow testing and it just totally washes out the front end wide. I've driven in the snow before with my old cusco 1.5 (you bought) and it was just power oversteer as soon as I touched the gas in the snow.
Now with the front rear cusco 1-ways (and the ATS setup of 1 way / 1.5way) I am power understeering. Wondering if I should just go back to the front helical or wait for the diffs to break in more. Maybe they are too tight to begin with.
I like how the car turns, I don't like how it behaves on power for exit.
had that issue since I got wavetrac way way back. been fighting it since. I had a full weekend with Dallas' ACD tune but I still struggled in the wet (had too much front camber for those events tho). Still looking for opportunities to learn its behaviour(s)
maybe there's something with the front diff that other guys are doing that we are not. I'm really tempted to swap the helical back in, if I can remember where I left it.
i don't mean the pros though - in the snow, turn, mash gas, should a front diff be causing power understeer?
In the snow, that's probably what's going to happen. You're asking too much from the front with so little grip. The wheels are spinning way to easily on power and locking up the center which is causing the understeer. If you want rotation a little handbrake yoink is what you need to get the shock and break the rear loose.
Which ACD tune are you running? The stock ECU snow programing is pretty amazing in the snow. But only so much magic can be done once in a terminal state.
