Yup should be bolt on, my Endless 6POT kit with 345mm discs fitted fine
Never used it before but its primary purpose is to clean a high mileage engine with less than ideal oil change intervals and its pretty good at it from what I've seen. From what I understand Valvoline claims to use some proprietary additive "PROPRIETARY SUBSTANCE OF HITEC 11188" that wont show up in an oil analysis, but it does have a good dose of detergents too. Its definitely lacking esters, zddp and moly for anti-wear though. Personally I would use a quart of HPL Engine Cleaner: HPL Engine Cleaner in your next oil change with oil that has better anti-wear properties.
Nice - I actually am a fan of the alcons, just need to decide between 343 and 355 - prob 355 even though I'll have to sacrifice my 17s again.
I did find the US Endless site, pricing is insane, even more than the Essex kits for seemingly less “Motorsport” calipers.
What does look comparable is in the 8k range…
You gotta buy Endless products directly from Japan. RHDJapan.com is a great site. I got their coilover line directly from japan and was about $1200 cheaper, with shipping, than purchasing in the US.
Originally Posted by black E
Cuz almost 6k 🤷♂️
Have AP’s on my C7z so I know what it’s like and I know it’s the best, just don’t track the Evo enough to justify the cost.
Endless EC670 6POT is their 2-piece caliper, it's a good quality unit and what i'm running on my car. Pedal feel is so much better than 20+ year old Brembo's.
If you want better than Radical Pro5000R calipers, then RacingMONO6 calipers are the way to go from Endless.
The factory Evo 5-9 Brembos are 320mm with 61mm annulus. The Evo X is 350mm with 61mm annulus. So there is good surface area and disc weight.
If you go to an Alcon or whatever, it's likely the annulus will be 54mm or smaller.
So just make sure you get the right kit for your application.
i didn't realize the annulus mattered, i thought it was just the torque arm of the brake (bigger rotor more brake) and the pad, as long as the pad fully touches the surface of the rotor, how does annulus play a role in braking?
genuinely interested/wondering.
annulus determines the height of the pad and with with pad length you get larger pad area. Larger pad will handle temp better, and provide longer life...
But, there is also a question of disc mass, which will determine how high are the changes in temp during braking, and you do not want those temps to spike too much. Then there is the disc gap... wider the gap, better cooling... smaller gap, with same disc width, more disc mass, and more temp stability (dont want those brakes to cool too much on the straights)...
Ideally, you adapt the brakes to the application and track.... For example, the grN brakes are 355mm with quite heavy discs, which is probably a result of the rally drivers stomping on their brakes all the time, but not having excessively long brake zones...
edited in: it is not really about the force and lever... more about the capacity of the system to transform kinetic energy into heat and transfer it to the air without getting the main parts too hot which will result in friction coefficient to drop and the driver will feel it as loosing brake performance...
yea very good points, no arguments here. I guess the only thing I would say is that usually those sorts of things (stability, etc, etc, etc.) go hand in hand with increasing the size and mass of the rotors, though I see what you mean by the annulus area helping, among other things, it will be a better heat sink as well.
I'm on the tiny ap racing brakes right now with ~325mm rotors. It's been a decrease in braking force compared to the Evo 10 setup I used to run, but benefits in other ways of course. I guess I'm just hoping to capture some of that back without "braking" the bank.
