Old Mar 18, 2021 | 11:52 AM
  #2941
kyoo's Avatar
Originally Posted by kaj
That's par for the course, I think. On my out laps, I have to be very careful. Very.
ok - yea just want to make sure it's not someting weird/bad with my setup. i guess as the tires get temps in them the fronts get overworked more and the rears fall into an ideal place as far as tire grip goes
Old Mar 18, 2021 | 12:01 PM
  #2942
kaj's Avatar
kaj
Shouldn't be overworked, though. Maybe ease up on the trail braking I have to do that when I want to push the car hard for more than a few laps. It's slower for me, but the tires stay happy
Old Mar 18, 2021 | 12:30 PM
  #2943
Dallas J's Avatar
Veteran: Army
There are a lot of things that change from cold to hot and by the nature of the Evo you arent going to get things to heat evenly. You will always go through 3 stages in just the tires. Understeer till front start working, once front is warming then oversteer till rear starts working, then get to you normal steady state.
If lap time is the most important things like time attack just ignore the warmup phase or just get through it driving 5-8/10s.But never setup your car to be better with cold tires at the sacrifice of warmed up grip.
Old Mar 20, 2021 | 08:44 PM
  #2944
Kevin.'s Avatar
Lube the cables? Wussat? I'd check the shift mechanism on the trans itself.
good call. Shift lever was tight and needed lubricant. Now working back to normal
Old Mar 21, 2021 | 07:31 AM
  #2945
kaj's Avatar
kaj
All fixed? Congrats, dude!
Old Mar 27, 2021 | 10:26 AM
  #2946
Lumpy Sticks's Avatar
5 Year Member
Back to racing this weekend. So if you guys remember, they threw the evo in the supercar class. Well my supra got thrown in the sport compact class haha. I thought I was going to get put in the sports car class but guess not. So looks like I get to go up against fwd cars, miatas and frs/brz....
Old Mar 30, 2021 | 06:42 AM
  #2947
kyoo's Avatar
potential causes of a weak start-up once in a while? doesn't matter hot/cold, could have been immediately driving, and once in a while just intermittently starts up slow. not the ignition part but the actual engine getting up to idle revs.. thoughts?
Old Mar 30, 2021 | 08:43 AM
  #2948
Biggiesacks's Avatar
Like it cranks slow, or when it fires off it kinda thumps a bit then gets going? If its the latter, I would probably jump down the IAC motor rabbit hole and see if that all checks out. If that checks out, then do the trinity of boost leak / compression / leak down tests.
Old Mar 30, 2021 | 08:48 AM
  #2949
Dallas J's Avatar
Veteran: Army
Weak ground on the starter harness usually. Check the ground on the harness is secured to one of the top to trans bolts and those bolts are tight.
Old Mar 30, 2021 | 08:53 AM
  #2950
kyoo's Avatar
Thanks, will check.
doesn't thump, it just kind of works its way up to idle slowly if that makes sense. Crank is good, all of that is good. Half the time it fires up as fast as ever, half the time just kinda slow..
Old Mar 30, 2021 | 09:01 AM
  #2951
Does it happen at any engine temp? Like first cold start, just restarted from OT, sitting for 20 minutes, an hour etc?
Old Mar 30, 2021 | 09:02 AM
  #2952
kyoo's Avatar
Does it happen at any engine temp? Like first cold start, just restarted from OT, sitting for 20 minutres, an hour etc?
yea any temp - if anything, it fires up faster cold, fires up slower after it's hot/been driven - but again, pretty random.
Old Mar 30, 2021 | 09:14 AM
  #2953
If it was me I would start troubleshooting the IAC, seemingly random in my experience tends to skew electrical/electromechanical. You can also try and make a mental note when it happens of how long the car has been sitting since it was at operating temp. Better would be to log coolant temp before starting. Then you can flush out if it is related to a specific temp range, which means it could be tune related / fixable.
Old Mar 30, 2021 | 06:57 PM
  #2954
kyoo's Avatar
resonated test pipe is in the car! holding on to the cat in case I ever go back to a state that requires a cat. hopefully the difference in backflow won't require a retune
Old Mar 30, 2021 | 07:12 PM
  #2955
kaj's Avatar
kaj
Going from a catalytic converter to no catalytic converter? Definitely want a retune
