The "why not" is you're basically throwing money away. A stock turbo can spike enough torque to break the stock motor with a stock manifold.
https://ajpdistributors.com/products...turbo-downpipe
i just confirmed this price is correct....
is it worth getting maps for their flex joint, or no? the rest of my exhaust is OEM fitment
Yea even the 02 housing is pretty cheap. I still have stock, wonder if this will be worthy?
https://ajpdistributors.com/products...pr_seq=uniform
yeah it will over stock
Anyone know of a roof antenna delete or if the base it screws into is still available? Looks like the plastic base of mine got brittle and broke. Was looking for some delete solution but came up empty handed.
https://www.maperformance.com/produc...9-evo-o2h-rev2
Lol. The MAP one is the same part, look at the gasket it comes with.
I don't think anyone make a quality fabricated O2 housing anymore.
These Invidia ones are nice pieces-
https://stmtuned.com/products/hs03ml...evo-o2-housing
Any turbo option for these car is capable of breaking the stock connecting rods, so if the motor isn't built, you don't need a manifold.
Got the car all back together and aligned this weekend. Been working on the ECU a ton and got to take it for a bit of a drive today. Noticed the steering would take a set when changing directions, maybe 5 deg at the steering wheel.
Had wife jerk wheel back and forth and verified steering rack was moving back and forth. I seem to recall last year thinking the steering was doing the same thing but much less.
Pulled subframe down as much as I could without dropping it and was able to tighten both locating bolts about 1/2 turn each. Hoping that's all it was.
