Old Mar 1, 2024 | 08:58 AM
  #5926
ViciousLSD's Avatar
Originally Posted by MrAWD
That is not a PG13 image for sure!
I had an open end lugnuts even before and they didn't help with corrosion getting in there. This one will get a bit of some anti-seize (sp?) with hopes it would protect it. Or, as you said above, just take them off every once in a while
my issue was the lugnuts got rounded off. dont use aluminum sockets and just replace the lugnuts when they look tired and dirty lol
and dont trust tire shop techs and their power tools
Old Mar 1, 2024 | 05:19 PM
  #5927
MrAWD's Avatar
This is what I use for lugnuts on OEM type wheels:
https://ezaccessory.com/products/chr...47734472212761
Old Mar 1, 2024 | 05:21 PM
  #5928
MrAWD's Avatar
Originally Posted by kikiturbo
You will need to get the calipers off, rear discs and possibly even pull the hubs out as IIRC there is no space to do it with hub in situ. Put some copper grease on every bolt as you do not want to strip caliper threads later on..
That sucks if the don't have an opening in the back plate. I guess, engineer who designed this stuff never had to replace those studs
Old Mar 1, 2024 | 08:42 PM
  #5929
LetsGetThisDone's Avatar
Rear studs require hub removal. Sorry man
Old Mar 4, 2024 | 10:42 AM
  #5930
Kevin.'s Avatar
Replaced the Walbro 255 with a new one and that fixed the lean condition but now seeing 9.5 afrs. Hopefully just a boost leak but I used an extra hanger from a 2005 - 1760A031 instead of my factory 02-04 hanger MN161238. Anyone aware of any differences between the two? Looks like a replacement holder is universal across all models: https://stmtuned.com/products/fuel-p...-oem-evo-7-8-9
https://www.extremepsi.com/store/OEM...II-and-IX.html
https://stmtuned.com/products/mitsub...ly-oem-evo-8-9
Old Mar 10, 2024 | 02:02 PM
  #5931
CaptainSquirts's Avatar
So did an autocross event today, went home and swapped to my DD set of wheels. I noticed one of my super pro lower control arm bushing is pretty much destroyed. I swapped a previous set of lower control arm super pro bushings about 6 months ago since they were cracked and bulging out. Pretty disappointed with the duroball since it only lasted at most 6 months(not sure when it failed), probably can handle DD duty but obviously it can’t handle autocross. Wonder if this aided in my last set of tires odd inner tire wear.
Anywho anyone have some recommended bushings for the front control arm rear bushing?
Old Mar 10, 2024 | 02:45 PM
  #5932
Dallas J's Avatar
Veteran: Army
Interesting failure. Maybe worth filling the gaps with urethane in it?
Old Mar 10, 2024 | 04:00 PM
  #5933
Ayoustin's Avatar
Powerflex has a pretty nice offset compliance bushings. Have a few customers with them who've had problem free exerpiences.
https://www.wunderladenracing.com/co...liance-bushing
Old Mar 10, 2024 | 05:32 PM
  #5934
I’m not sure since it looks like it’s separating from the metal sleeve itself?
Old Mar 10, 2024 | 05:45 PM
  #5935
But have they taken their cars fast around any corners? 😆
Old Mar 10, 2024 | 08:37 PM
  #5936
Meathooker's Avatar
ive got a Perrin psrs kit listed in the market place
Old Mar 11, 2024 | 12:20 AM
  #5937
ViciousLSD's Avatar
the whiteline offset bushing/caster kit worked well for me.
Old Mar 11, 2024 | 10:04 AM
  #5938
Ayoustin's Avatar
IIRC one of them is a somewhat avid autocrosser. The body of the bushing isn't made from poly like the Superpro so I wouldn't expect it to suffer a failure like you're seeing.
Old Mar 11, 2024 | 11:03 AM
  #5939
Bee-Raddd's Avatar
This is what i have also with no issues.
Odd failure. Like dallas pointed out maybe due to the holes in the bushing its not strong enough for autocross
Old Mar 11, 2024 | 11:42 AM
  #5940
ViciousLSD's Avatar
probably operated outside of its range. maybe shocks are too long?
