Tiny bubbles; should I be concerned?
Old Aug 22, 2020 | 01:00 PM
kaj's Avatar
kaj
What up guys? I'll get right to it:
This is the only caliper that does this. I'm assuming it's just air getting sucked around the tubing or the bleeder. None of the other calipers do this. Should I be concerned?
calipers were mostly dry when I put them on and this side brake line lost a little bit more fluid than the other.
https://youtu.be/n4KnMMtxR4Y
Old Aug 22, 2020 | 02:38 PM
yip's Avatar
yip
Looks like air coming around the bleeder. What method do you use to bleed?
BTW, I loathe bleeding brakes. Just swapped out my calipers on my Golf R and it took 3 full bleeds to get all the air out
Old Aug 22, 2020 | 02:57 PM
Balrok's Avatar
I use the motive bleeder - pump it to 15psi and do at least 3 wheels before having to add fluid usually. But when I don't have a good seal on the hose it tends to suck eraser sized bubbles. I'll normally get those tiny *** bubbles on the first crack after a weekend, bleed for a bit and close. I don't really check for open/close/open/close. If you're good on fresh fluid making it's way there then I'd replace the screw, they're cheap enough.
Old Aug 22, 2020 | 03:21 PM
kaj's Avatar
kaj
All new fluid and front calipers. I use a motive bleeder at 8psi because anything near/over 10psi starts splitting the old hoses. I had my engine bay sprayed, fixed it, then filled up my camber plate/strut tower area with about 8oz of fluid, which ran down onto the shock.....the upright....etc, when it burst again.
it was so fun.
I did notice the bleeders on the caliper sit a bit more loose than the others, while open. I'm 99% sure that was it.
I take my stuff to the track anyway, so fingers crossed!
Lastly, looks like the X calipers already have SS pistons, so no need to upgrade?
Old Aug 22, 2020 | 03:29 PM
LetsGetThisDone's Avatar
X calipers do not come with SS pistons. They're aluminum just like 8/9
Old Aug 22, 2020 | 03:35 PM
kaj's Avatar
kaj
​​​​​​they sure look shiny. Chrome plated?
Old Aug 23, 2020 | 02:00 AM
If they're stainless, they're not factory.
Old Aug 23, 2020 | 10:12 AM
kaj's Avatar
kaj
They came from eBay, so no history. Weird thing is, they sent me two passenger-side calipers, so you would assume from different cars.
Old Aug 24, 2020 | 11:28 AM
kyoo's Avatar
it will take a number of bleeds to get all those out. i've bled my brakes 1,000 times, several times with new calipers
Old Aug 24, 2020 | 11:40 AM
RazorLab's Avatar
it was so fun.
Old hoses on what? The motive? They cost like $10 to replace.
How you can get any good bleeding from 8psi, I have no idea.
Old Aug 24, 2020 | 01:11 PM
kaj's Avatar
kaj
Yes, but I needed my brakes done before new hoses would get here. The brakes bled just fine at 8psi. No complaints.
Old Aug 24, 2020 | 01:31 PM
Biggiesacks's Avatar
The guys at lancerregister are pushing gravity bleed, compared to that 8psi is pretty serious.
Old Aug 24, 2020 | 07:05 PM
kyoo's Avatar
what is gravity bleed?
Old Aug 24, 2020 | 07:32 PM
You just fill up the master, open up a bleeder and gravity moves fluid from the higher reservoir out through the lower open bleeder. They say it's about 10 minutes per nipple.
Old Aug 24, 2020 | 07:49 PM
kyoo's Avatar
ah that's how i "bleed" a new caliper i install anyway. once it starts coming out i put the motiv on though
kon575
Jul 6, 2011 09:01 AM
Bigl4201
15
Jan 27, 2011 10:10 PM
AngryEvo8
Jul 5, 2009 08:00 PM
LetsGo82nd
Feb 19, 2009 08:10 AM
truDriver
Jul 3, 2007 06:15 AM
