Standalone ECU motorsports thread
If you read above that is pretty much what I’m doing. I’m just learning as much as I can and need to get the car at least driveable to get a few miles on my diff r&p before it sees any big load.
I have a full baseline file and I’m comparing and migrating files one at a time to check the difference in things cause I’d rather learn it than just letting others do everything. Trial by fire right now.
And again, Lucas (owner of English Racing) will be working his magic when I can get my schedule to align with his
To an extent. easy to screw something up and do some major damage in an ecu if your not careful. but yea definitely good to play around and learn the software so you can make changes when required
Guess and check is NOT the correct way to tune or make adjustments, you should be 100% confident in any change you make by fully understanding why you are making said change and how said change will effect the calibration/engine. It will be a bit of a learning curve but you'll pick things up very quickly i'm sure and be LOADS more confident in your self and car/ECU which is always a good thing.
Most importantly enjoy the learning and experience along the way!
Small update, got my date scheduled for Lucas to work on the tune. Should get a good bit of time with him to learn all the things and get it running tip-top.
Once I get the car back together I'll put some miles on the car to burn off old e85 and switch to pump gas. Just need to finish swapping some springs, change some oils, and an alignment.
Overall it’s been pretty great. Definitely see how the motec solution is really built for the professional teams because there are so many things that can overlap and take control but I’ve learned a ton. I’ve also added DBW with a kit I’m working on for o-ringed Bosch 68mm and EvoX throttle pedal. It’s been absolutely flawless on my car. Wife had no clue I changed anything cause feel and position of the pedal is perfect.
Still need JRR to modify the files so it can read steering angle correctly. I have my own solution but would be good to have it correctly working.
Now I’m trying to figure out how to get an auto blip downshift but I need to tie in some sort of logic for both clutch and brake in to indicate a downshift.
those are crazy numbers for that turbo. What style of dyno? Phou has the 2.0 on his car and did 480 hp and 350ish ftlbs. Heck the hill climb car just got tuned last week and it did 560hp with a g30-770.
getting auto blip will be nice.
we have a steering angle sensor tied into the emtron but haven’t played with it much. Someone at emtron had a base map for the acd to get started and we haven’t messed with it much it’s on the to-do list.
Im sure I posted it somewhere but 420 on pump @ 18psi and 520 on e85 @ 30psi tapering to 27ish.
The OEM steering angle sensor is an encoder with center pin that’s low for seven steps with the middle being center. The motec just looks for an analog input so it’s not doing it right. I have an arduino to read the encoder and output a 0.5-4.5v signal.
The other thing I want JRR to change is the way out put is added. Theirs a throttle and brake map and that’s added to a slip map. Thats pretty good but on the slip map I want to add a steering rate axis
That way I can have 3d maps for throttle/braking vs steering angle vs speed and add slip vs steering rate vs speed.
Anyone run one of theses:
https://emtron.world/products/evo-ix-plugin-ecu
tryimg to figure out the easiest way to get flew fuel on a street car and stumbled across this.
