Time Attack Advice
Old Mar 7, 2022 | 08:54 PM
  #571
ViciousLSD's Avatar
Thanks gents.
@Dallas J Thanks. This could be a sign so I should take it from ya. YGM. I should be hearing it if its in contact with the fork right?
Old Mar 8, 2022 | 12:14 PM
  #572
LetsGetThisDone's Avatar
Originally Posted by Dallas J
You don't really need the clutch stop with the monolock. What happens on OEM TOB is the ring pops off the back side and that cant be pushed back in. If a monoloc pops out you can pop it back in. Though I've never heard of one popping out.
Can confirm, never heard of nor have I had a monoloc popout. The fork stop will require constant adjustment if you run it close enough to the fork to actually do anything, and again, its simply not needed with the monoloc. The fork stop was something that came out prior to the monoloc being a thing.
Old Mar 8, 2022 | 12:18 PM
  #573
kaj's Avatar
kaj
Thanks gents.
I know you asked Dallas, but I check mine before each event as part of my routine.
Sounds like nobody else is using them, so possiblity no need.
Old Mar 8, 2022 | 01:40 PM
  #574
ViciousLSD's Avatar
cool thanks! Maybe some guy who hasnt gone thru the trouble might need it
Old Mar 8, 2022 | 10:15 PM
  #575
ViciousLSD's Avatar
maybe @black_out might need it
Old Mar 9, 2022 | 08:04 AM
  #576
black_out's Avatar
I definitely have no use for it, part of me enjoys the Russian roulette style driving this car requires
Old Mar 9, 2022 | 09:02 AM
  #577
ViciousLSD's Avatar
my tow truck guy was arguing with his wife while I was getting towed off the track. see what happens when the wife is towing you off the track
Old Apr 19, 2022 | 04:36 AM
  #578
TheYellowBatman's Avatar
For those running brake ducts from the front of the car, have you found much difference between 2.5" to 3" brake ducting? I run mine to mounts on the caliper which then force air into the middle of the rotor like the binary engineering ones. After installing the 3" ducting from nothing I found a big difference in stopping capability however I'm looking to improve it further by running NACA intakes either side of the intercooler rather than just an open duct. There may not be a lot of room there for a 3" inlet though so I'm considering going to 2.5".
Have you also found much improvement replacing the various rubber mounts (engine, diff, LCA etc) with the harder delrin ones?
Old Apr 19, 2022 | 08:03 AM
  #579
ViciousLSD's Avatar
I immediately removed the urethane transmission mount... thats just too much vibration/distraction, so i have only 2 urethane mounts in the engine bay. I have all urethane bushings for the suspension. for me this is general maintenance and reducing variables when setting alignment. diff mount is urethane which i'm sure makes a difference when launching the car from stop, which would be rare
Old Apr 19, 2022 | 09:53 AM
  #580
kaj's Avatar
kaj
I have a poly roll stop I didn't really see any reason to replace the other mounts. I did do the rear diff bushings as well. All of my non-spherical suspension bushings are now poly. That was a no-brainer for me as the OEM stuff allows for a lot of unintended movement. I noticed the most difference when I took it to autox. The car definitely feels sharper everywhere, though.
Old Apr 19, 2022 | 12:10 PM
  #581
Bee-Raddd's Avatar
2.5 is heaps
Old Apr 26, 2022 | 10:02 AM
  #582
alpinaturbo's Avatar
Brad, heaps - as in sufficient and plenty of air flow?
Old Apr 26, 2022 | 12:34 PM
  #583
Bee-Raddd's Avatar
Yep i have 2.5" and its plenty of air. can get away with 2" depending how fast your going
Old May 21, 2022 | 03:51 PM
  #584
ViciousLSD's Avatar
Hey gents. QQ, does the CT9A have a fuel pickup issue below quarter tank? I felt some hesitation while going over a crest so had to quit my session.
So I finally got my track day... nothing broke yippee!. EvoX brakes, SRF fluid and cooling helped but I still dont have much confidence. I cant go to COTA with these lol. I'll need to have different coilovers for autox and track so I'm going to work on that next.
Old May 21, 2022 | 04:19 PM
  #585
kaj's Avatar
kaj
I can't get my X brakes to fade. ST43s, Ti shims, SS pistons, good fluid....
I'm impressed.
But, if I can go with something aftermarket that works as well and lets me go back to a 17 inch wheel, I will definitely do that.
