Time Attack Advice
Old Sep 3, 2021 | 06:16 AM
  #76
Terror Rising's Avatar
maann. everyone at the paddock blurted 'motul' (claims to be instructors who chose to live near the track, but just there to chitchat). I'll put srf after this weekend's TT. I was going to remove the 5.0 pads and switch to my old HPS (i know its not for TT duty, but its what I have) but the 5.0 pads finally stopped squealing after the TT We also have track sprints prior to TT, what track day pads would you recommend? Thanks
Raybestos ST-43 used to be a go-to and still is what I use for auto-x & HPDE. I run those, titanium shims, and brake ducting. I wish I would have put in SS pistons when I rebuilt my calipers last time but oh well. Next time they need a rebuild they'll get replaced with radial mounts.
Old Sep 3, 2021 | 08:11 AM
  #77
Ayoustin's Avatar
Originally Posted by bee-raddd
Most good brake fluids are within 50deg or so in boiling point. When ur talking 600deg C 50deg C isnt much difference.
Basically if you boiled 1 fluid ull likely boil all fluid. As you said definately focus on brake cooling as its a big issue on evos. both front and rear brakes we found get too hot
Sounds like he's running Valvoline DOT4 which is a parts store synthetic fluid, it's definitely not up to the task of track abuse. Also, brake fluid temps are in F, at 600C the brake calipers would be close to melting by the time the fluid is boiling lol. Also, another point that's often overlooked when comparing higher end fluids is compressibility, which definitely has a decent impact on pedal feel.
Originally Posted by razorlab
Motul sucks. I ran it for years, then got faster and wondered why my pedal would always be soft. I thought I was just "too fast". Then I switched to real brake fluid. At the time that was Torque, now it's Castrol SRF. I used to bleed my brakes at every event, now I go multiple events before having to bleed and no soft pedal. Anyone that says motul works well is either slow or on a go kart track.
Those hawk 5.0 pads aren't doing you any favors either. Get some real pads.
I run RBF600 in all my cars that see track use. Certainly not the best of the best but cheap and readily available at plenty of places compared to more exotic fluids. I don't think I'll ever need anything better for the Fit tho may step up to 660 for the evo or maybe try something else.
Old Sep 3, 2021 | 08:16 AM
  #78
RazorLab's Avatar
SRF actually costs me the same if not less because I don't have to bleed the brakes after every event. You can also get it on Amazon easily.
  #79
RazorLab's Avatar
Can't go wrong with ST43 pads in the front. They last forever too.
Old Sep 3, 2021 | 08:18 AM
  #80
ViciousLSD's Avatar
Borrowed from ECS tuning website. A little weird the HP+ is shown with higher cof but I stand on that for autox while I just stab my 5.0
I read HPS 5.0 is low dust so that's not what I have. "Street/Race 5.0" is probably DTC-30?
which one is similar to ST43, for reference?
Old Sep 3, 2021 | 08:27 AM
  #81
ViciousLSD's Avatar
I bought both lol. I thought I screwed up ordering since i read "factory line" on the bottles. Looks like my minivan is going to get motul this winter (maintenance)
Old Sep 3, 2021 | 08:28 AM
  #82
RazorLab's Avatar
Here are the Raybestos. If you notice, the ST43's stay very stable across a wide range of temp, only starting to drop off after 1200F. They also don't eat your rotors as much as other track pads.
I actually drive with them to/from events. No issues.
Old Sep 3, 2021 | 08:45 AM
  #83
Vicious, wait until you use the ST-43s at an auto-x. The first time I did I slowed down for the first turn, sped back up, and slowed down a second time because they worked so well compared to the Hawk trash I had been using. They've never come out of the car since.
Old Sep 3, 2021 | 09:15 AM
  #84
ViciousLSD's Avatar
Its probably like the "street/race" with bonus dust. :"Street/Race" is also night & day, had to adjust first few times. Grinding stoppage just backing off my driveway. I'll get some later if it has less dust and I would not need to buy sonax to clean my wheels lol. Looks like Hawk stickers are coming off. Thanks.
Old Sep 3, 2021 | 09:17 AM
  #85
Lumpy Sticks's Avatar
5 Year Member
I have a set of front st43 pads brand new in the box and some ti shims if anyone needs them.
Old Sep 3, 2021 | 09:18 AM
  #86
kyoo's Avatar
i actually loved the st41s on track. couldnt believe how good they felt
Old Sep 3, 2021 | 09:56 AM
  #87
Construct's Avatar
Be warned that the ST-43 (and other race compounds) can have incredibly loud squeal during street driving.
They're great on track, but if you drive the car on the streets you'll likely want to switch back to regular pads between events.
Old Sep 3, 2021 | 10:52 AM
  #88
Dallas J's Avatar
Veteran: Army
For AutoX, the ST43 doesnt come up to temp and has too much bite. Thats not a good thing when your abs is trying to modulate.
I switched around to a few different things and settled on XT10s being perfect for AutoX and intermediate track.
Old Sep 3, 2021 | 11:02 AM
  #89
I have not had issues with temp but I live in Texas. Rotors have a nice purple sheen to them after every event. ABS doesn't seem to care about the bite and I really only light up ABS at course endings. Now, I'm not your level of prep but I would think that it would have shown itself worse on 255 street tires than 315 hohos.
Old Sep 3, 2021 | 11:16 AM
  #90
ViciousLSD's Avatar
From Tirerack's website
Not sure if DTC-30 or Street/Race 5.0 is discontinued. I cant say I agree with this chart. The HPplus doesnt have a bite at all, unless theyre swapping names/compounds
Anyone notice Hawk fluids have the same bottles as Motuls
