TeeJay's Quest For 700+whp Stock Block discussion thread
TJ's Quest For 700whp! Tuning Updates!
As most of you know we had a huge build for TJ's Evo X. Today is the day we are going for 700whp on a 1.2CF on the stock ecu and stock bottom end w/ upgraded arp rod bolts.
This Car Is Built With:
ETS HTA3586 Tubular Turbo Kit
ETS 5" IC W/ Race Pipes
ETS 4" Intake
Kelford Stage 2 Cams W/Springs
ARP Head Studs/ARP Rod Bolts
Greddy TBE
Walboro 255 w/ Inline Bosch 044 Fuel Pump
HKS 1200's
HKS Fuel Rail
HKS FPR
ClutchMaster's Stage 5 Clutch
We are working on the pump gas tune now, then we will drain the tank and fill with VP Import...
ETS 4" Intake
Greddy TBE
HKS 1200's
HKS Fuel Rail
HKS FPR
Some Pump Gas Updates...
22psi 11.5 A/F 93 Octane
So far so good, these numbers seem to be inline with ETS's personal car on pump gas. I believe they made 530/540whp with the 3586 at 23/24 psi so things are looking good. [CENTER]
For the amount of boost being used we are right inline with ETS who is using the same setup on their car. I believe they made 530/540whp @ 23/24psi so we are looking good at 22psi!
We will have more updates as soon as we drain this tank and put some Import in the tank.....
