TeeJay's Quest For 700+whp Stock Block discussion thread
Old Oct 17, 2009 | 12:06 PM
  #241
DG Motors's Avatar
Originally Posted by Thugline
what happend to making more than 629whp on 93...or are u guys just making it safe for tj to drive the car daily?
We made 629whp with a much larger turbo than TJ's 3586. We are leaving the car at 579whp for a solid daily driven tune.
We are draining the tank right now. Throwing in some VP Import and taking some more tire pressure out since we are spinning on the rollers.....
Old Oct 17, 2009 | 12:09 PM
  #242
DG Motors's Avatar
Pump gas tune is done!
Ok, we are done with the pump gas tune. 579whp @ 25.5psi, we are draining the tank and putting in some VP Import!
We are encountering some tire spin which means we are on the right track to making some serious hp..Time to drain some tire pressure too, updates coming up in 30 minutes.
Old Oct 17, 2009 | 12:12 PM
  #243
meggs00's Avatar
KEEP IT UP! lets see how far this 4b11 will go
Old Oct 17, 2009 | 12:21 PM
  #244
06MREvo's Avatar
jesus...those are some sick #s for 93 oct and only 25psi...nice job DG Motors & Charlie... Looking forward to the VP #s...good luck...
Old Oct 17, 2009 | 12:31 PM
  #245
cnj4ever's Avatar
awesome cant wait to see the final result from this build. Just another reminder of how bad it sucks to be in germany instead of back in the states. Good luck guys hope for the best
Old Oct 17, 2009 | 12:47 PM
  #246
kmc8302's Avatar
Numbers are sick keep up the good work, hopefully ill be able to stop by and check the car out soon!
Old Oct 17, 2009 | 01:02 PM
  #247
infumis's Avatar
the 579 is that pump gas/meth?
Old Oct 17, 2009 | 01:19 PM
  #248
monkey_187's Avatar
Great numbers on pump gas, I cant wait to see what the car does on some import!
Old Oct 17, 2009 | 01:29 PM
  #249
projekX's Avatar
from my fone guys:
633.0 @ 27.5psi
Old Oct 17, 2009 | 01:31 PM
  #250
projekX's Avatar
gettin some major wheel spin. letter some air out the tires and crankin up da booooooost
Old Oct 17, 2009 | 01:34 PM
  #251
Evo a Mula's Avatar
No all pump gas baby
Old Oct 17, 2009 | 01:37 PM
  #252
monkey_187's Avatar
67 more to go!!!!!
Old Oct 17, 2009 | 01:39 PM
  #253
BlackTrack's Avatar
Originally Posted by DG Motors
We are comparing numbers to a local dynojet...
On that dyno a Stock X makes 264whp?
My car made 234whp stock on AMS' dynojet, which would be a 1.070 Correction Factor in comparison to the 219.7whp you posted that "Andre's" stock X made.
(Not trying to turn this into a dyno debate, but a 1.2 Correction Factor is pretty serious.)
Old Oct 17, 2009 | 01:54 PM
  #254
kozmic27's Avatar
sweetness...
Old Oct 17, 2009 | 01:55 PM
  #255
blackdemon's Avatar
I should have got up my lazy *** and went to see this.
