Philadelphia's Classiest Drunkards
Old Apr 28, 2011 | 07:48 AM
  #21541
grillpt's Avatar
Originally Posted by 06RS
You know me, it's all about the JDM bling factor!
Nope, they just removed the manifold, welded the hole cleaned it out and put a phenolic spacer on. Whether that translates to any additional power, who knows. If nothing else we removed weight, potential boost leaks and made the car 100% emissions non-compliant. Everything I've read about the spacers say that the intake manifold will become noticably colder to the touch.We were originally going to plug the head, but I wasn't terribly comfortable having to worry about a potential catastrophic engine failure should that plug ever come loose. As it turned out, the shop where my friend is tuning the car has an excellent welder on staff, so welding the hole shut was a no brainer.
I have one on my car, can't say that I've ever noticed a big difference.
Originally Posted by AlwaysinBoost
show before go, thats what I always say.
I'm curious to see your results with the spacer. I was going to run one when I did my HG install over the winter. I've had great results using them on other motors but i was advised against it with this one because I was told it doesn't hold up and eventually causes boost leaks.
I heard the same thing, its been on my car for almost 2 years now, and it seems to be holding fine. That being said, I've probably only put 10k on my car in that amount of time. Adam is the one who installed it, and I got it from Chu. (thanks again buddy!)
Old Apr 28, 2011 | 07:50 AM
  #21542
chu's Avatar
chu
Pete, thats becasue you still have EGR and your exhaust is circulating through the mani. Ben is complete removing the system and block off the flow, so his should, in theory, run much cooler.
Old Apr 28, 2011 | 07:54 AM
  #21543
AlwaysinBoost's Avatar
Pete, Adam is actually one of the people who advised against it...
Old Apr 28, 2011 | 08:20 AM
  #21544
grillpt's Avatar
I understand that, I don't think it makes that big of a difference though. We should do a test at an autox event, right after a run get the thermal number off the intake mani from two of our cars, Ben's and someone else's (who is still on stock IC), and see if there is a difference.. I know Marc has one of those thermal guns we could use. You usually have it with you don't you, Marc?
I know, thats why I said that.
Old Apr 28, 2011 | 08:34 AM
  #21545
with the EGR blocked off/removed I'd bet there would be a difference in IM temps. I don't usually bring my IR gun to autox's, but I can. Problem is I don't know when I'll be able to make it to another one...
Old Apr 28, 2011 | 08:38 AM
  #21546
chu's Avatar
chu
You're such a diva now!
Old Apr 28, 2011 | 08:48 AM
  #21547
why's that?
Old Apr 28, 2011 | 08:53 AM
  #21548
grillpt's Avatar
Yeah he is..
Old Apr 28, 2011 | 08:54 AM
  #21549
ninja please.
Old Apr 28, 2011 | 09:53 AM
  #21550
dek0026's Avatar
So who's up for some hardparking this Sunday at the sonic meet?
I completely forgot about it. It would be nice to hang out for a little while with some beers if the weather is nice.
Old Apr 28, 2011 | 10:02 AM
  #21551
grillpt's Avatar
I'm working 8hrs on Sunday, no hard parking for me.
Old Apr 28, 2011 | 10:17 AM
  #21552
robertg's Avatar
I'm there, all our TST buddies will be there too.
Old Apr 28, 2011 | 10:31 AM
  #21553
igo4bmx's Avatar
Man Dressed as Cow Steals 26 Gallons of Milk
http://www.nbcwashington.com/news/we...807919.html?dr
  #21554
igo4bmx's Avatar
u guys going to sonic?
what if we join in an buy two vip spots in the grass and then set up a table and play beer pong?
thoughts?
Old Apr 28, 2011 | 10:48 AM
  #21555
grillpt's Avatar
^ My guess is you will probably get arrested. It would be a good time though...
