Philadelphia's Classiest Drunkards
Old Nov 29, 2011 | 05:43 AM
  #30466
chu's Avatar
chu
Originally Posted by AlwaysinBoost
where do I know that guy from?
Originally Posted by evremonde
he is from the south jersey region right? drives the volvo station wagon ?
You got it Kenny. He's the tech chief for SJR, and drives that Volvo wagon!
Chau, James, and I did their last event back in early November. The guy did an instructor run in my friend's car (beat the crap out of it btw), came back and told me and Chau that he thought it was a good run, but we should be able to beat him. He said he ran a 76.xxx. Meanwhile, I stopped checking air pressures, looked up, and said "we already did." Guy walks away. THe three asians had a good laugh about it!
Old Nov 29, 2011 | 05:45 AM
  #30467
AlwaysinBoost's Avatar
lol, thats it. Dude drives the wheels off that wagon.
Old Nov 29, 2011 | 05:56 AM
  #30468
chu's Avatar
chu
He really does! He's got the big and heavy f'er turning pretty well. He just rubbed me wrong when he beat the ***** of my friend's car instead of trying to show him the proper line and technique. Actually, all of the instructors there were like that. One even spun a student's car, twice! I talked to Aaron about it, and they wouldn't let him, nor I, instruct becasue they didn't "know" us, yet we beat most of the field.
Old Nov 29, 2011 | 07:28 AM
  #30469
grillpt's Avatar
Sup y'all?
Old Nov 29, 2011 | 07:32 AM
  #30470
its not what chu know that matters, its who you know!
Old Nov 29, 2011 | 07:37 AM
  #30471
dek0026's Avatar
I know everybody and everything
Old Nov 29, 2011 | 07:48 AM
  #30472
chu's Avatar
chu
Good advice!
Old Nov 29, 2011 | 08:01 AM
  #30473
BBS's Avatar
BBS
Here is a spin at thunderbolt coming out of the chicane.
http://vimeo.com/m/24853025
I dont get it. It wasnt even raining...were the wipers necessary?
Old Nov 29, 2011 | 09:14 AM
  #30474
Kevin.'s Avatar
I meant to respond earlier, Kevin, but I forgot. Anyway, if you dont already have it figured out, to me it sounds a like a decent sized boost/vaccum leak. Running rich at idle would make sense if air is getting sucked into the Maf and metered, but not making it's way to the Im.
Have you tried boost leak testing it?
Good idea. It's been a while and haven't worked on this car. Totally forgot about the whole boost/vacuum leak stuff. I might of blown a pipe off somewhere. I'll check the system.
Swapped plugs out, did nothing. No new CEL came on. Still waiting. Not really drivable so CELs might not come on.
Old Nov 29, 2011 | 09:15 AM
  #30475
Kevin.'s Avatar
Front O2 sensor hard to swap on a stock motor EVO 8?
Old Nov 29, 2011 | 09:23 AM
  #30476
dek0026's Avatar
Last I heard it was impossible.
Old Nov 29, 2011 | 09:36 AM
  #30477
Kevin.'s Avatar
Same with being a milkman
Old Nov 29, 2011 | 09:48 AM
  #30478
dek0026's Avatar
Don't come at me bro!
  #30479
psushoe's Avatar
I like the kick the tires an put a sticker on it approach to tech. Makes for higher throughput of cars.
Maybe next year I'll qualify as an instructor... I finished third in PAX with going to only 2 out of 6 events.
Old Nov 29, 2011 | 10:25 AM
  #30480
I was gonna say, if its drivable you can bring it to my garage in lansdale and we can boost leak test it real quick. Other than that I'd say start looking around for leaks. If you don't see any obvious ones it might be time to get a portable compressor and leak tester.
depends. if you have the OEM o2 housing I believe you have to remove the hotside/turbo/manifold because the o2 housing heat shield is in the way. Its been so long since I had the stock o2 housing so I honestly don't remember. with most of the aftermarket o2s you do not need to remove anything to access the sensor. If you don't already have an aftermarker o2 now is the time to get one especially if you have to remove your stocker to replace the sensor.
what makes you think your sensor is shot? are you getting a code for it?
