Philadelphia's Classiest Drunkards
Old Dec 20, 2011 | 08:26 AM
  #31231
Tims2006MR's Avatar
Auto x starts in 88 days!!! I know you track ****** don't care lol
Old Dec 20, 2011 | 08:31 AM
  #31232
chu's Avatar
chu
I'm excited for it!
Old Dec 20, 2011 | 08:44 AM
  #31233
quadrophine's Avatar
I gotta start tracking... how much do lessons cost? I've found with my clutch aggressive driving makes for much smoother gear changes. I'm getting much better, perfect shifts 4 out of 5 for daily driving but every now and then I jerk it a little. and chu and honda guy are the instructors how for away from philly are you guys and your respective tracks?
Old Dec 20, 2011 | 08:53 AM
  #31234
chu's Avatar
chu
^I'm not an instructor, but Always-In-Vacuum and honduh-guy are.
There are no cost for "lessons," just cost per track day per organizations, and you get an instructor with the price.
I live in north Philly, and NJMP is closest at about 1 hr drive.
Old Dec 20, 2011 | 09:04 AM
  #31235
dek0026's Avatar
Chu, will you be my instructor in February?
  #31236
dek0026's Avatar
Quadrophine, have you driven stick before?
Old Dec 20, 2011 | 09:05 AM
  #31237
dek0026's Avatar
Also one could expect around $200/per track day. It's usually a little less but that's just an average.
Old Dec 20, 2011 | 09:51 AM
  #31238
right on... chu where in north philly are you? i'm from juniata,
almost every car i've driven has been stick, save for an altima and a jeep liberty. it's just the clutch on this thing is heavy and the ratios between gears are so short it's more like a truck tranny than anything. My 90 wrangler had an easier trans than this. and my whole drivetrain has been upgraded to handle over 350 tq spinning 35's on 4.11s. when i'm pushing it and shifting between 7500 and 8500 my shifts are perfect consistently it's also my granny shifting needs a little work, i'm used to my wrangler which has about 193 torque at 1500 rpm, so i keep forgetting that keeping the rpms that low in higher gears i'm lugging the poor engine. on the other hand, rev matching when i downshift at higher speeds is spot on... it's my low end, 3k and under that i'm having a lil trouble with
Old Dec 20, 2011 | 09:54 AM
  #31239
So what does the instructor do? do they just put you behind the wheel and tell you to start driving and explain how to enter exit corners? when to brake and when to accelerate? and how long do you get to track for that $200 +-
also, what does ftw mean?
Old Dec 20, 2011 | 10:09 AM
  #31240
chu's Avatar
chu
^How old are you? :LOL"
Im down G & Tioga!
Old Dec 20, 2011 | 10:10 AM
  #31241
dek0026's Avatar
Our cars have like no low end torque and the gearing is tricky if you're not used to it. 4k rpms shifts for around town driving is what works best in my car. That is part of the reason I don't like daily driving it.
Average track time for HPDE is around 2-2.5 hours or 4-5 sessions.
Instructors tell you everything you need to know and hopefully keep it on the pavement and off the walls.
Old Dec 20, 2011 | 10:14 AM
  #31242
dek0026's Avatar
And FTW means "f-ck the white man" because we gangsta up in here.
Old Dec 20, 2011 | 10:18 AM
  #31243
chu's Avatar
chu
I wouldn't necessarily say no low-end torque in these cars. In any case, it sounds like you may have an "ultimate ratio" trans build, sine you mentioned 4.11. Do you know what kind of clutch you have in there? Sounds like a drag-type setup! It may be the type of clutch that in the car too, some of which are like on/off switches.
  #31244
Tims2006MR's Avatar
It this is your first performance car? I am new to the autox/hpde element of driving also. In my opinion I would get used to driving the car in a normal manor, as you were saying you are trying to smooth out your driving. Auto cross is a great place to learn car control and pushing your car under 65mph. HPDE/track days are a lot of fun, I did my first on this past summer. A good instructor is key to keeping you and your car in one piece. At njmp you need to be comfortable with your driving and car so all inputs are smooth and executed precisely because at 120+mph things happen very quick. There are some very skilled drivers in here and they will have some better advise for you. FTW means for the win
also- your post about looking for a place with a skid pad and a place to push your car that is not on a closed course probably is not the best idea if you are still trying to learn to DD an evo.
Old Dec 20, 2011 | 10:26 AM
  #31245
zabes's Avatar
what groups you guys run with mostly? i saw that nasa and audi club (neq) have their schedules up so far. also gotta get ray to one this year
