Philadelphia's Classiest Drunkards
Old Mar 14, 2012 | 05:18 AM
  #33946
AlwaysinBoost's Avatar
Originally Posted by honda-guy
in other news, i was spraying some wd40 on manifold studs in preparation to remove the turbo and notice i was missing at least two bolts to the 02 housing. i did notice there were some exhaust coating under the hood at the end of last year but i thought it was the manifold seal leaking since it was on the other side of the 02 housing. but i didn't get that valve tapping sound like chu did when he lost a bolt to 02 housing
#1 WD40 is for newbs. Real men use PB blaster... waiting for Petey to come in a say what he uses that is 10x better.
#2 Told you them bolts be backing out, B!
Morning bishes.
Old Mar 14, 2012 | 05:31 AM
  #33947
Mr. MR's Avatar
Dan, that is an insurance claim, you should only have to pay deductible if you have comp and collision. Did you look into claiming it yet?
95 at rush hour is a combat zone, could have happened to any of us. Well not us autoxers cause we have lightning reflexes, just track guys. I meant to say it would have happened to any of you track guys..
Old Mar 14, 2012 | 05:32 AM
  #33948
chu's Avatar
chu
< Have heard KROIL is the shiznitz.
Fineberg, bring them brackets on SUnday son!
Old Mar 14, 2012 | 05:33 AM
  #33949
Mr. MR's Avatar
Originally Posted by grillpt
Dan, do you have a place to take it to? If you need a good place (not a trans shop), drop me a pm and I'll give you the info.
Whats with everyone and the o2 bolts... Me, Chu, now Thai. Geez...
My ish has been good since my buddy took care of it for me. Everytime I tightened them they just came loose again after a seesion or two.
Sounds like a job for Hi-Temp loctite. Is there such a product?
Old Mar 14, 2012 | 05:47 AM
  #33950
honda-guy's Avatar
Morning bishes.
i usually use ZEP 45 but i ran out, and wd40 is what i had laying around.
Old Mar 14, 2012 | 05:53 AM
  #33951
BS. I've seen you autox. You hit errthing not moving... and even some things that do move.
Dan if you are claiming on insurance make sure you tell them the chair fell off a truck and struck your car in mid-air. Don't say it was laying on the ground and you ran into it.
Old Mar 14, 2012 | 05:57 AM
  #33952
grillpt's Avatar
Thats the stuff Petey loves. We use it here at work, it stinks like a **** but works like no other.
Truth!
Old Mar 14, 2012 | 06:00 AM
  #33953
igo4bmx's Avatar
does it matter?
  #33954
chu's Avatar
chu
I pulled apart a set of Evo rear knuckle/wheel hub/brake yesterday. Now, how the heck does the ABS sensor come out? I removed the 12mm bolt, and the damn thing doesn't budge. Not sure if the sensor is still good, but I don't want to ruin it if it is, so I haven't tryied anything other than oulling by hand. Ideas?
Old Mar 14, 2012 | 06:09 AM
  #33955
^ its seized to the hub. Some PB blaster or koril and a little muscle should do the trick.
Old Mar 14, 2012 | 06:11 AM
  #33956
igo4bmx's Avatar
don't forget stage 8 or nord lock washers
Old Mar 14, 2012 | 06:26 AM
  #33957
chu's Avatar
chu
Didn't know the plastic can seize....I'll lather it in PB tonight!
Old Mar 14, 2012 | 06:34 AM
  #33958
dek0026's Avatar
thanks pete. i took it to chester county transmission today. i also took the day off of work. i heard good things about them and they seemed like no nonsense (not like the type of shop that wants to replace my windshield wipers and pcv valves in addition to what i brought it there for).
i couldn't have avoided it without getting into the car next to me and the lady in front of me swerved to where i would have hit her if i swerved in her direction too. eating the chair was probably the better of the 3 options.
I thought about all that. not sure i'm going to claim it unless it needs a new transmission or something. i expect costs to be at or under my deductible anyhow.
Originally Posted by igo4bmx
does it matter?
yes. if it were laying in the road and i hit it, it would be collision. if it fell on to my car from the truck it would be comprehensive and my rates wouldn't be affected.
i don't carry comprehensive coverage on that car and with my company anything that you hit or hits the car is covered under collision. when my wife's BMW was hit while parked in a parking lot and the dude took off, they said it was considered collision since something hit the car.
none of that makes sense. isn't insurance coverage there to cover things when the car hits or get hit by something? and doesn't the policy differentiate between the different types of hits? to them it's all collision.
yeah just don't try to remove it the way you tried to remove the corolla's rotors a couple of years ago......it'll never work
Old Mar 14, 2012 | 06:42 AM
  #33959
chu's Avatar
chu
^stfu
Old Mar 14, 2012 | 06:43 AM
  #33960
only the outer casing is plastic. the abs sensor is metal (magnet)
