Philadelphia's Classiest Drunkards
Old Apr 2, 2012 | 02:29 PM
  #34546
shuttlegoose's Avatar
Still trying. I havnt bumped my thread in awhile but I had a few serious buyers. I think mine is priced basically at the lowest I would take (which is really low IMO) and you still get lowballed. I'll put it to you this way, the demographic of people who want an Evo can't afford to pay you for what it's worth.
Old Apr 2, 2012 | 02:34 PM
  #34547
BBS's Avatar
BBS
I paid 17k for my friends 9 mr with 76k. So your price seems reasonable give its mileage. Tim, youre going to have a harder time at 20k cause youre close to 80k and people assume that a new motor/drivetrain = ragged on.
Old Apr 2, 2012 | 03:07 PM
  #34548
honda-guy's Avatar
you fools be smoking crack. i pulled my wheels off just to make a point. the pin is stainless, so obviously its not magnetic but the retaining clip is steel so it's magnetic. unless its made from some special secrete chinese sauce plastic that's magnetic developed for NASA space station.
if you have a loose pin, maybe the hole in the aluminum caliper is worn out, but i think there's a steel sleeve in the caliper so the aluminum doesn't wear out but i haven't look closely to confirm that.
Attached Thumbnails Philadelphia's Classiest Drunkards-2012-04-02_17-45-05_866a.jpg
Old Apr 2, 2012 | 03:24 PM
  #34549
Mr. MR's Avatar
Hey genius, of course it sticks to your magnet, it is steel pin, but the end is wraped in some type of non steel material. Do I have to pull my pin to show you how its boggered up? Would do it now, but car is getting aligned at RT!
Old Apr 2, 2012 | 03:28 PM
  #34550
dek0026's Avatar
Fineberg = RT nutswinger.
Old Apr 2, 2012 | 03:34 PM
  #34551
honda-guy's Avatar
hey retard, did you read my post. the pin is stainless = non magnetic. the retaining clip is steel, so it's magnetic. i put the i put the magnet to the pin and it doesn't stick, it only stick to the clip. so you saying the pin is plastic now
Old Apr 2, 2012 | 04:04 PM
  #34552
Mr. MR's Avatar
Got it fool!
Ok Ok, the pin is stainless and the "collar" is some type of metal. My "metal collar" is all beat up. I am going to replace the pins just in case. The pins still go in there fine, but after losing both rear clips I figure it can't hurt to replace.
Old Apr 2, 2012 | 04:06 PM
  #34553
Mr. MR's Avatar
Best alignments in town biotch!
For realz, they are giving my car a once over and fixing a few things I cannot or don't know how. Nothing major hopefully, only one issue has me slightly worried. I may need to replace the valve seals, which would be gay.
Old Apr 2, 2012 | 04:24 PM
  #34554
dek0026's Avatar
Only gay people replace valve seals.
Smoke = manly
No Smoke = Gay
RT is a great shop. They should do you right.
Old Apr 2, 2012 | 04:58 PM
  #34555
chu's Avatar
chu
Furthermore, all shades of blue are gay...
Old Apr 2, 2012 | 05:14 PM
  #34556
dek0026's Avatar
Especially if it's blue smoke.
Old Apr 2, 2012 | 06:05 PM
  #34557
honda-guy's Avatar
Got it fool!
were the pins still in place when the rear pads clips were gone? i dont see how the clips would have came out with the pins still in place. i did notice the pad clips on chu's evo 8 was slightly different then my evo 9, the springs has less tension on the evo 8 clips.
i don't see how your pins could be beat up if you don't take the pads out much, for autox. i removed my pads at least 20 times last season from testing various pads and rotating pads, and i see no noticeable wear on the pin collar.
Old Apr 2, 2012 | 07:13 PM
  #34558
Mr. MR's Avatar
I only loss rear clips, all pins were still in place, real bizzare. I never lost a pin, just pins on front calipers are a little boggered up. Rears are still looking fine. I used to track my car a few times, prolly just beat up the pin one time when hammering it in.
Old Apr 3, 2012 | 03:18 AM
  #34559
dek0026's Avatar
whachu talkin bout?
Old Apr 3, 2012 | 04:05 AM
  #34560
psushoe's Avatar
Fineberg is talking about how his pin is old and been hammered so much it is not functional.
