Philadelphia's Classiest Drunkards
Old Dec 8, 2010 | 06:41 AM
  #14791
igo4bmx's Avatar
loving breakfast
Old Dec 8, 2010 | 06:52 AM
  #14792
Tims2006MR's Avatar
is their a way to disable the pats system with evoscan?
Old Dec 8, 2010 | 07:04 AM
  #14793
turbotekray's Avatar
You can disable it on Tephra V7 go to periphery
Ecu periphery (faa)
Look at Bit 2 and change the value to 0
Perfect if you dont want to spend 200.00 for an extra key lol
Old Dec 8, 2010 | 07:16 AM
  #14794
Tims2006MR's Avatar
Ecu periphery (faa)
Im going to have to figure out how do do that. Im doing my new alarm and remote start and my car only came with 1 key and cant program the bypass. thanks
Old Dec 8, 2010 | 07:18 AM
  #14795
Its easy tim, did petey tune you on Tephra?
Old Dec 8, 2010 | 07:43 AM
  #14796
Tims2006MR's Avatar
im not sure, i need to learn about this! haha
Old Dec 8, 2010 | 07:58 AM
  #14797
chu's Avatar
chu
Someone school me on how to check for a bad coil-on-plug, using a multimeter. Thanks
Old Dec 8, 2010 | 09:15 AM
  #14798
Set your ohmmeter to the 20000 ohms range. Turn on your meter and touch the spark plug wire terminals on one of the coils with the meter leads. You may get a reading between 5000 to 15000 ohms, Find out from spoolin what you should see. This checks the secondary resistance.
Set your ohmmeter to the 10 ohms range, and touch the terminal B+ (usually the center prong on the coil pack electrical connector) with one of the meter test leads, and touch the corresponding coil prong on the electrical connector with the other test lead. You may get a reading between 0.3 and 1.0 check with spoolin what it should be. This checks the primary resistance on each coil.
and suck it
Old Dec 8, 2010 | 09:27 AM
  #14799
dek0026's Avatar
and suck it
ray, i've been trying to follow these steps with chu here and he can only get step #3.
Old Dec 8, 2010 | 09:29 AM
  #14800
dek0026's Avatar
in other news: my car isn't paid off yet so i refinanced it for the remaining years. it was worth it. if you guys are still paying on your cars, most of the credit unions in chester and montgomery counties have like 2-3% interest rates on used cars.
  #14801
LMFAO!!!!!!!!!{thumbu p}
I'm not surprised
Old Dec 8, 2010 | 10:02 AM
  #14802
chu's Avatar
chu
Dan was no help either! We're still on the irst plug!
Old Dec 8, 2010 | 10:09 AM
  #14803
chu's Avatar
chu
Marc, Pete G., Ben B., Kenny...someone jump on this..
https://www.evolutionm.net/forums/sa...pad-350-a.html
Old Dec 8, 2010 | 10:24 AM
  #14804
AlwaysinBoost's Avatar
what do those rotors go for when new?
I'm on the fence with the whole 2-piece rotor deal. I understand the benefit with regard to rotating mass, but the thing I can't get past is that when they crack you have to take the old rotor apart and install a new ring... that is assuming you have a spare ring available to use.
With the solid rotors I get for $20 a corner @ rockauto all you do is throw the old one out and install a fresh one. Takes about 8 minutes. Its less work and cheaper. If I were at the track and cracked one of those fancy two piece rotors it would take who knows how long to reinstall a new one, which means lots track time... just sayin'
Old Dec 8, 2010 | 10:29 AM
  #14805
chu's Avatar
chu
New PFC's are $750 + shipping. I don't know what replacement rings go for. I only posted that because I think its a great deal. If I didn't have rotors, I would buy them in a heart beat.
