Need help
Old Feb 2, 2013 | 08:11 PM
lovemyoutlander's Avatar
Need help
I have a 2012 outlander sport I purchased some led bulbs for above my license plate but cannot figure out how to install it and where is the access to change the bulbs out?
Old Feb 2, 2013 | 08:35 PM
fluxcapacitor's Avatar
open your trunk, and the big giant plastic cover on inside has to be removed. There are a few clips around that you have to search for and remove and once you do then you can remove that panel and you will be able to access the bulbs.
Old Feb 2, 2013 | 08:40 PM
Ok thanks so much hoping it doesn't take long and will get it done tomorrow.
Old Feb 3, 2013 | 12:52 AM
Burtonrider1002's Avatar
EvoM Moderator
Yeah... no.
The panel inside the trunk is for replacing the reverse lights. To get to the license plate lights you slide the clear plate to the *right*, and it should pop off.
Correction, slide them to the right, not left. https://www.evolutionm.net/forums/10480705-post11.html
Old Feb 3, 2013 | 11:08 AM
^^ i did it my way and i had access to it perfectly, it's still a way to get to it so dont' say its wrong when it is a still another way to do it.
Old Feb 3, 2013 | 11:31 AM
EvoM Moderator
Searching for multiple clips and removing interior panels is definitely not the "recommended" way, and according to Mitsubishi, it IS wrong.
Old Feb 3, 2013 | 12:29 PM
trying
everything you guys are saying but nothing moves
Old Feb 3, 2013 | 12:41 PM
got it i pushed it to the left and it worked thanks.
Old Feb 5, 2013 | 10:23 AM
XSTeknique's Avatar
Originally Posted by Burtonrider1002
Yeah... no.
This IS how the manual says to do it.
Old Feb 5, 2013 | 01:54 PM
EvoM Moderator
Yes, it is. And to clear up any future confusion:
blackandredgts
Apr 12, 2016 01:59 PM
john blaze
Jan 10, 2014 12:06 PM
i.Apotheosis
Lancer Troubleshooting
Mar 27, 2012 07:07 AM
tim85851
Nov 28, 2009 02:46 AM
Nasty Evolution
Jun 28, 2009 11:43 AM
