Brembo Brakes for the O.S.
Old Oct 17, 2015 | 08:08 AM
  #76
Morgan Carter's Avatar
Of course ^^^
Old Oct 19, 2015 | 06:11 PM
  #77
Nast_Nas's Avatar
Idk if any of you own a 08+ Lancer or RA. But Andrew Pye his name is Drew316 on here. He's on evom and multiple lancer/X/RA FB pages and also clubralliart. He produces a 6 piston bbk for all 08+ lancers. Ready to ship and be put on with just a minor modification.Uses all oem parts that can be rebuilt and replaced at any autoparts store. And must have a proper wheel setup for it to clear the caliper. Uses CTS-V caliper and X rotors. I own a RA but also will own the OS starting tomorrow. Now I put this on here to say as the outlander sport shares the same front brake setup with the lancer. I've checked and he's confirming as well. Andrew is a very trusted and well known lancer/RA connisseur of parts. Here's some link to some pages. If any of you are apart of FB on Ralliart Revolution or Team Not Evo you will know what I'm talking about.
https://www.evolutionm.net/forums/09...d-working.html
http://clubralliart.com/showthread.php?t=3952
Old Oct 19, 2015 | 06:21 PM
  #78
Nast_Nas's Avatar
Null.
Old Oct 22, 2015 | 05:38 PM
  #79
So I've found out that to do the rears I need to swap to the ralliart rear axle or maybe just hubs. Prob is the stupid OS has a cable parking brake that works on the caliper in the rear. Most use a drum style parking brake. So if I were to put the rear brembos on I'd lose the parking brake and I don't want that so for now I'm just doing the fronts once the adapters get to me and I'll wait to do the rears. I'd hope I could just swap in ralliart rear spindles n hubs and then be setup with a drum parking brake but I'm not sure
Old Oct 22, 2015 | 07:56 PM
  #80
infected's Avatar
Just curious if you also plan to swap out the master cylinder for the larger calipers? I also wonder if this will affect all the ABS, ASC, TCL, and EBD functions.
Old Oct 22, 2015 | 07:59 PM
  #81
CottageLifer's Avatar
I know ABS (even the real German!) but what are the other TLAs???
Old Oct 22, 2015 | 08:47 PM
  #82
Should have no effect. It didn't on my eclipse None of the sensors are in the calipers
Larger master might add braking force but don't think it's needed. Once the rears are done a diff pro portioning valve would let the rears do more work. I thought about an EVO one for it then
Old Oct 23, 2015 | 03:13 AM
  #83
wolfdima's Avatar
Evo master will make braking curve much steeper but will not affect peak breaking force much. At least that what I heard from Andrey-TT (Asx Evo guy).
Old Oct 23, 2015 | 06:16 AM
  #84
infected's Avatar
Here's an article on the topic you may find of interest. Or simply just goodbathroom reading material:
http://stoptech.com/technical-support/technical-white-papers/abs-and-big-brake-kits
From a guy who's had BBK's on every vehicle from older models without allthe bells and whistles to newer ones, just wanted to share some info or foodfor thought. Not to say a haphazard setup will be catastrophic for everydaydriving, but sometimes everyday driving is when these safety systems are reliedon the most without us even realizing it.
Old Oct 23, 2015 | 06:10 PM
  #85
Good read. I understand how all the systems work and haven't had problems with the many other vehicles I've done bbk kits on like you. Not to say that all swaps won't have issues either. It's a better feeling knowing someone had done it already and put the car thru its paces and is satisfied with it too
Old Jan 7, 2018 | 10:27 AM
  #86
Chayanne30's Avatar
Hello guys im new to this forum i have a Mitsubishi outlander SE 2009 i want to put brembo calipers from evo c would they fit
Tractionlimit
Apr 10, 2011 03:08 PM
Massimo Power
Evo 'For Sale' Suspension / Brakes / Handling
18
Nov 7, 2008 07:37 AM
BoostIt
Aug 17, 2008 02:00 AM
beebers
Dec 15, 2004 10:26 AM
Jordan J
Jul 24, 2004 12:12 AM
