My JDM EVO IV
Old Aug 13, 2011 | 05:44 PM
  #196
APEX'iEvoIV's Avatar
have been busy with it, have a water/meth set up on it and bumped the boost up a bit
results so far
fitted a SPOOLINUP COP kit
also got a VII rocker cover and painted it marble blue
moved the battery to the boot, had a underdrive alt pulley made as you can't buy the pulley by it's self underdriven.
new catch can fabricated
fitting welded to sump for drainback when racing
current engine bay photo, I also wrapped the UICP to stop heat soak from the radiator fan blowing hot air on them it has stabilised the IATs alot and dropped them by about 10 deg C through out the range with power runs being between 6-8 deg C above ambient at 29psi.
Bridgestone RE55s fitted as I am prepping it for track work
it is curently at the suspension place getting corner weighted and offset caster bushes fitted to the front and a track alignment.
Old Aug 16, 2011 | 07:01 PM
  #197
VR4_EVO_IV's Avatar
Lookin real good.
Old Aug 16, 2011 | 07:14 PM
  #198
RallyBud's Avatar
Great car....it gives me a "warm & fuzzy" inside!
Old Aug 17, 2011 | 02:21 AM
  #199
Thanx guys, got is back from the suspension guys today, corner weighted, offset caster bushes fitted and track alignment
Old Aug 17, 2011 | 09:23 AM
  #200
Alchem1st's Avatar
Looks good man! Have you considered putting Brembo's on it? It was a cheap and easy upgrade that made alot of difference for me.
Old Aug 20, 2011 | 03:01 AM
  #201
Yeah my track wheels won't fit brembo's but my new street wheels will might look into it in the future, got some ENKEI SC 24 and some cheap 225/45 tyres as the camber will chew them out and I don't want to be spending 100s on replacing them
fitted the eliptech shiftlite
Old Aug 20, 2011 | 03:11 AM
  #202
jr_2006IXMR's Avatar
beautiful
Old Nov 19, 2011 | 03:09 PM
  #203
motor is out after wrist pin failure, not impressed with this as it wasn't making that much power, pistons are manley sport comps
so far I have got for the rebuild
ARD forged knife edged crank
FP HTA GREEN turbo w/ 25psi actuator, 1450cc FIC injectors for E85, balance shaft removal kit, windage tray and crank scraper, and new lifters will wait and see what manley have to say about the pin failure but will most probably be getting WISECO HD pistons this time.
I have got a Evo IX oil cooler to replace the VII one I had prev
just fits
Also got some Aero latches and fitted them
hoping to be back on the road early next year all things going to plan
Old Nov 20, 2011 | 05:34 PM
  #204
Mistaken's Avatar
Man that's clean.
Old Nov 20, 2011 | 10:45 PM
  #205
cheers bro, hope to make good power on E85 with the HTA green, will be winding it up and going for gold
Old Nov 21, 2011 | 02:51 AM
  #206
SaulHudson's Avatar
What in place of your clock in dash?
Old Nov 21, 2011 | 03:18 AM
  #207
Alchem1st's Avatar
+1 and also sell me your passenger airbag delete/storage compartment! (or at least give me first dibs if you ever do! )
Old Nov 21, 2011 | 11:20 PM
  #208
it is the controller for the APEX'i EL guages
Old Nov 27, 2011 | 11:01 PM
  #209
CP pistons
coated manifold
hope to be going again early next year
Old Nov 28, 2011 | 03:21 AM
  #210
Alchem1st's Avatar
Dude that's awesome! I'm guessing you had the SAS bungs welded on? That's what I need...
