My JDM EVO IV
Old Apr 10, 2012 | 05:23 PM
  #256
cversoza's Avatar
Looks awesome. Well done and put together.
Old Apr 17, 2012 | 01:40 AM
  #257
APEX'iEvoIV's Avatar
cheers mate
Old Jul 8, 2012 | 01:03 AM
  #258
pix from our EvoNats at Wakefeild park raceway
Race seat for the track
fitted
the tow rig, not my car that is the boss's 4WD
vid at the motorkhana when the turbo died
found a restriction in the exhaust as I was swapping it over for a 3 inch cat back
The OEM flanges were welded onto the cat that was fitted, that is a 3 inch gasket
So I cut them off and got some 3inch pipe and flanges and welded them on
As posted in tech my turbo died at this event
Looking into the cause as I am told it was due to not enough airflow to the turbo
Old Jul 22, 2012 | 02:35 AM
  #259
Turbo is off being fixed, new muffler fitted
K&N air filter fitted, had to do some customising to make it fit
bit tight here
all better
should be going again in a few weeks will be having a touch up tune done as well
Old Jul 22, 2012 | 02:38 AM
  #260
before I put the recaro back in I decided to fix the squished bolster
took a trip to the local shop that sells foam and stuff, got a bit cut for 12 bux
little bit of time with a knife
all better
Old Jul 22, 2012 | 08:41 PM
  #261
Papa Smurf's Avatar
nice!!
Old Jul 24, 2012 | 02:22 PM
  #262
Fastone_evo6's Avatar
Originally Posted by APEX'iEvoIV
Well the breakages continue, engine this time
Got some goodies for the forged rebuild to be done soon
FP WHITE RABBIT turbo
that pistion does not look good , and i tought you said that your enginge was fully built?
Old Jul 24, 2012 | 11:00 PM
  #263
that is the stock piston mate, hence my motor now being 'fully built', pretty sure if you read further on from that post you will see my motor upgrades.......
As per that quoted post of mine above the pic of the injectors :
Old Aug 3, 2012 | 12:51 AM
  #264
turbo has been rebuilt by GTPumps here in australia, it now has the heavy duty thrust bearing
Dyno vid
sorry in KW but hp=KWx1.34 so 327.5x1.34=438.85hp
Old Aug 3, 2012 | 01:08 AM
  #265
RepoManEvo's Avatar
looks nice
Old Aug 3, 2012 | 11:31 PM
  #266
cheers mate
so when I was putting the turbo back on I managed to strip the thread on one of the drain back bolts in the sump but didn't have time to fix it before the tune so today was the day.
Off to the auto store, 15 buck 3inch exhaust chrome tip, there are no exhaust shops open in beauy on sat and I didn't know what size pipe I need, which is 3 inch btw.
Just cut the pipe on one side and pull it apart a bit, don't forget to cut a recess for the oil pick up, which I did first time
that other welding is some stress cracks from the spotwelds that I welded ages ago.
Also welded on another nut for the oil return bolt
And I will now say that my car is scary fast
compared to before.... WOW it going to take some getting used to...
Old Oct 7, 2012 | 05:26 PM
  #267
went to the drags, had major shifting issues, so here is my summary of tonight:
my first run I bogged off the line, missed 2nd and 4th ran 13.5 @ 107.46 2nd run more revs off the line massive wheel spin grabbed 2nd bogged down missed 4th again ran 12.09@118.61 3rd run mass wheelspin again missed 2nd and bogged when I grabbed 2nd missed bloody 4th again ran 13.08@117.02 it started to rain so we packed it up and went hom I got NFI why I couldn't get the gears..... =/ it pulled 34mph thru the top end in that 12.0 run tho =)
was up with my mate in his red 9
here are the vids in order, 3rd run I missed 2nd as well
andre wins I miss 2nd and 4th
I win, still miss 4th
3rd run against a falc turbo ute I miss 2nd and 4th... again......
Old Oct 16, 2012 | 02:20 AM
  #268
changed the cable bushes, feels better already, just waiting on a new shifter cradle
Hrmmmmmm what have we here
Old Oct 16, 2012 | 04:33 AM
  #269
Alchem1st's Avatar
Nice! Just did the cable bushings on mine as well! Cool easy mod that can be done in minutes and very worth it!
Old Oct 19, 2012 | 11:13 PM
  #270
for sure, yesterday I did the shifter base ones as well and wow what a difference, so glad I did it very worth while mod to do.
