My JDM EVO IV
Old Oct 20, 2012 | 07:12 AM
  #271
Alchem1st's Avatar
Yeah, I have the Blitz aluminum ones. I've never used another shifter that feels so good! Mitsu's design is top notch and you can certainly tell it was derived from their motorsports program.
Old Nov 1, 2012 | 03:20 AM
  #272
APEX'iEvoIV's Avatar
yeah very impressed with the feel of it now, anyway I made some improvements to the catch can breather setup, added another breather and put larger inlets on the catch tank
here is the latest VDR run after the change
Old Dec 31, 2012 | 05:02 PM
  #273
maybe this is why I have been having trouble with the gear selection........
welded both of them up, not sure why they need to have bonded rubber joining it together but anyway, all solid now, shifts awesome, so much better
Old Jan 26, 2013 | 07:08 PM
  #274
bit of work since last posted
changed the gearbox breather as I didn't want E85 fumes going to it
Also had a bit of spill with the fuel and it ate the paint so I decided to pump the rear guards as they needed painting anyway
this is with a 235/40 on a +40 rim
the drivers side buckled of course
so took it to workand tidied it all up
all painted and back together I fixed the crappy guard gaps while I was at it and the fuel filler
from this
to this
waiting on my door decals
got a taiwanese CE lancer bootlid for a GT wing when racing
because I do not want to modify my OEM bootlid
will have one of these fitted to it when I get it
Old Jan 26, 2013 | 07:11 PM
  #275
personalised plates
Old Jan 26, 2013 | 07:14 PM
  #276
RE55s fitted to the 8 rims, will have these as my street rims with Federal 595 RS-R tyres, I am sellin the RE55s off
Old Jan 26, 2013 | 07:15 PM
  #277
so finally got to finishing of the exhaust
bought a 3inch stainless flange
cut off the step down
welded the flange back on, my stainless welding is getting better
now the muffler sits in a bit better
Old Jan 26, 2013 | 07:17 PM
  #278
decided to raise the wing a bit
firstly wasn't real happy with these brkts
costed up making some new struts and that was a bit stupid, more than the whole wing cost me so plan B was to replace those brackets ^^
got for nix from my friendly local sheet metal guy :thumbsup:
now sits this much higher
finished em off the next day
forgot to bring my laser cutter home so jig saw and file it was, not perfect but hey I am not either
bit of etch prime and satin black
mmm that's better
Old Jan 26, 2013 | 07:19 PM
  #279
here it is in all it's glory, Evo 7 rims with 235/45 Yoko A050 these will be my track rims and I will be using hankook Z221 after the yokies wear out
has got good clearance after the guard work
same on both sides
needs the rear camber tho I think
and from the back
will use the Evo 8 rims for streeties
centre caps were a slightly different colour so I got them done too
have some DBA 5000 2 piece rotors and Brembo calipers coming will run Endless pads for track
Old Jan 26, 2013 | 07:45 PM
  #280
Alchem1st's Avatar
Nice! Love the Evo 7 and 8 rims much more than the old black ones you had! Side angle shot with the wing on? There's a Voltex wing for an 8 for sale near by. I'd love to snag it so badly! Too much monies tho...
Old Jan 26, 2013 | 09:46 PM
  #281
cheers mate, yeah I quite like the 8 ones, not a huge fan of the 7 rims but they will do for track work.
That wing I got thru a chinese company it is pretty much a copy of a GTC-Drag wing but 1/10th the price, I am yet to test it once I get the Brembo's on it I will get it to the track
I haven't got a good side shot with the raised mounts, weather here is terrible at the moment so it is safe in the garage, will get one soon once it clears up.
Old Feb 6, 2013 | 12:44 AM
  #282
the Brake upgrade is underway, ordered these DBA 5000 2 peice rotors
bought some Brembo front calipers (ignore the rotors I just bought the calipers )
also got some 'titanium heat wrap' for the front pipe to keep oil temps down
put some blue LEDs into my instrument cluster, might see if I can make it light up a bit better somehow
the camera didn't really work too good, it is not as bad as it looks that dark patch
Old Feb 6, 2013 | 09:57 AM
  #283
jrswann's Avatar
Sick!
Old Feb 7, 2013 | 11:06 PM
  #284
bought some screw fit inflators for my Evo 8 rims
waiting on the other bits to arrive, will fab up a air guide for my oil cooler again too when I get the rest of the stuff
Old Feb 22, 2013 | 12:20 AM
  #285
some pix with the E8 enkeis and new tyres on, they drive ok, don't like fast direction changes but they are just for cruising, don't really do 'spirited' drives these days
Also got my new oil temp sensor and fitted it, good to have that working again
Just waiting on rotors ........ still........
got my calipers back, tried the stencil for the writing, worked ok but I think it might need to be removed straight away as we waited till it was a bit dry and didn't come off 100% nice but they look way better than before and I am not that concerned
