My JDM EVO IV
Old Dec 22, 2011 | 02:53 AM
  #226
APEX'iEvoIV's Avatar
some goodies arrived today
Old Dec 22, 2011 | 11:12 PM
  #227
all finished
FP oil line/filter
here is the green next to std IV turbo
Old Jan 6, 2012 | 12:09 AM
  #228
All back together and going, running it in atm, going the 'hard run in' route this time, have done nearly 300klms did a vdr run just for interest sake on 98 pulp and wastegate pressure, will be winding up the boost and switching to E85 once run in properly
took some pix while out and about
Old Jan 6, 2012 | 12:14 AM
  #229
SaulHudson's Avatar
Did you dyno on stock motor? What were you making?
Old Jan 6, 2012 | 02:19 AM
  #230
std motor made 226.8kwatw with a VI RS turbo and the same cams
Old Jan 6, 2012 | 02:49 AM
  #231
SaulHudson's Avatar
Those are good numbers. I made about 300 base with a few bolt ons.
Edit : For no confusion, HP I'm talking not KW. I think it was like 297kw base.
Old Jan 6, 2012 | 12:25 PM
  #232
yeah 226kw is about 320ish hp, 297 kw is near 400hp.
Old Jan 7, 2012 | 11:13 AM
  #233
evo4nr's Avatar
Hi from a fellow E4 Owner.
Old Jan 7, 2012 | 01:22 PM
  #234
Hi back
Old Jan 8, 2012 | 02:50 AM
  #235
evo4nr's Avatar
Here's mine;
Virtual Dynograph;
Good to see some proper Dyno Dynamics graphs on your thread
Old Jan 8, 2012 | 10:25 PM
  #236
holy crap, bit of engine work there eh lol, must be wild, I am hoping mine will go 430hpatw lol
Old Jan 9, 2012 | 10:42 AM
  #237
evo4nr's Avatar
430 might be a bit of a push on a green hta mate. I think 400 would be VERY good.
Old Jan 9, 2012 | 10:52 PM
  #238
yeah we'll see I guess, I will be running E85
Here is the VDR run I did a few posts earlier in DYNO JET as yours is done
That is on run in tune with wastegate pressure (25psi) on 98 PULP
Old Jan 10, 2012 | 09:19 AM
  #239
evo4nr's Avatar
I put them in dynojet as it's what most guys use on here. On a Dyno Dynamics in proper shoot-out it's making just a tad over 500WHP on 98 RON same as yours in 3rd gear.
I find if you put your graph in virtual dyno and put in a custom CF=0.9 that seems to read just like a dyno dynamics.
Do you have any earlier graphs when you had the runs on dyno dynamics.
Old Jan 10, 2012 | 10:59 PM
  #240
Yes I found VD uncorrected gave me comparable numbers to the dyno mine normally goes on.
This motor is not run in yet so I have not had it tuned, my prev motor the dyno graphs are posted when I have had it on the dyno, I never dyno'd it with the water/meth, I am going to be booking it in for tuning on E85 in the next few weeks and will post graphs once finished.
I have built this motor more for response than outright power as I am prepping it for track work.
