Evolution 2 wide body for WTA - pic heavy
Old Feb 21, 2013 | 02:43 AM
  #76
dougmo's Avatar
yep, one is enough, I dont have headlights, heater etc...
The only thing not run through it is the heated front screen and rear "fog/tail" lights
Old Mar 8, 2013 | 11:32 PM
  #77
Evo_Someday's Avatar
I REALLY like that fender work. I could use something like that since I've gone overboard with fat tires that stick out.
Old Mar 9, 2013 | 04:47 AM
  #78
justincase's Avatar
what class you planning on running in this year mate?
Old Mar 9, 2013 | 05:54 PM
  #79
dougmo's Avatar
Thinking of moving up to pro-am this year, still weighing it up at the moment though.
I have to add a bit of extra weight to run in open.
switch panel is coming along too
Old Mar 9, 2013 | 11:32 PM
  #80
oufan2929's Avatar
Just read this whole thread! Nice build!!
Old Mar 10, 2013 | 08:13 AM
  #81
talentsearch301's Avatar
nice build!!!
Old Mar 15, 2013 | 03:44 PM
  #82
dougmo's Avatar
Thanks Guys
Old Mar 22, 2013 | 11:56 AM
  #83
kaya's Avatar
hey mate, wanted to ask how those ignition cables are called?
Old Mar 24, 2013 | 08:40 AM
  #84
deylag's Avatar
I like the thought process of this build. What is your power goal?
Old Mar 25, 2013 | 05:39 AM
  #85
dougmo's Avatar
they are magnacore leads, custom made to my requirements
power goal is around 450h-500hp(real ozzy ones) @ wheels, if I can get around that level I will be close to where I need to be power to weight wise.
The weight goal complete with full aero is about 2070lbs wet
other work continues, the switch panel was finally completed today which is great!
The main fuel tank is also back in for the final time, now just the filler system is required as it doesnt use the original system anymore.
-10 teflon feed hose running to the carter lift pump and then into the surge tank
The intercooler pipes are now also back on, silver ceramic coating on hot and cold side
the turbosmart Race port in place too
Old Mar 30, 2013 | 01:35 AM
  #86
dougmo's Avatar
Old May 3, 2013 | 03:47 AM
  #87
dougmo's Avatar
The dash came up quite nicely
I just need to get it to fit around the cage now
once i have modifiedit to fit it will be matte finished along with the motec CDL surround, I'll get them done together so they match.
Dash is in almost, just need mounts off the cage to hold it more solidly now.
I removed the dump today also and put some heat sheidling onto the bottom of the sump as the dump is quite close (3.5")
fuel tank has also been done on the exhaust side
adjuster for the power steering pump is also done
Old May 3, 2013 | 10:31 AM
  #88
bsh's Avatar
bsh
Wow very nice work there
Old May 10, 2013 | 03:19 AM
  #89
dougmo's Avatar
thanks mate, progressing along now hopefully fire it up again next week with the motec
Old May 23, 2013 | 02:47 AM
  #90
BDI's Avatar
BDI
Mate, what a build! Love it - Always puts a smile on my face to see love for the earlier evo's.
Cant wait to see it finished! - That bumper looks alot like the old Chester Evo II one?
