New WW IX MR
Old Oct 19, 2015 | 09:46 AM
  #271
kaj's Avatar
kaj
Increasing rebound? Wouldn't that make the rear extend faster?
Sounds like you would want to soften it.
I'm no suspension expert, though LOL. I may be thinking it out wrong.
Old Oct 19, 2015 | 04:31 PM
  #272
electron bom's Avatar
gawd this evo is gorgeous...
thanks for the under-tray btw!
Old Oct 23, 2015 | 09:28 AM
  #273
kyoo's Avatar
from what I understood, since the rear end is coming up so much, I do want the shocks to react/extend faster to keep the wheels more in contact on the ground.. I think. I'm really not interested in getting new/different coilovers period, so this is it for me. another event on sunday to try out the softer rear bar - same site, should be similar conditions. may try firming up the shocks all around to see what that does - I've been autoxing at 17 clicks from full stiff on my ohlins dfvs, which is fairly soft.
here's an outside view on a different run - not my best but shows I'm fighting power oversteer a little right around the 28s mark exiting a corner. I sound like a broken record but I need get sticky tires and see how the car feels with those on.
thanks! your build is amazing, can't wait to see the progress. hope the undertray works out for you.
Old Oct 23, 2015 | 09:45 AM
  #274
mrbonilla's Avatar
you're so lucky man, i hope your build goes well.
Old Oct 23, 2015 | 11:08 AM
  #275
kaj's Avatar
kaj
I'm no suspension expert, so I'm not sure. Plus some single-adjustables adjust compression and others rebound? LOL
I need to research.
Old Oct 23, 2015 | 12:44 PM
  #276
LetsGetThisDone's Avatar
You want slower/stiffer/more rebound damping to hold the back of the car down.
Old Oct 23, 2015 | 02:42 PM
  #277
kaj's Avatar
kaj
Okay. I may have misunderstood what my car was doing. I was pogo'ing all over the place. Too much rebound. softening it up helped a ton.
Old Oct 23, 2015 | 05:45 PM
  #278
When referring to damping changes, always refer to the damping. More/stiffer rebound damping means the wheel moves slower, less/softer rebound damping means the wheel moves faster.
Your post doesn't make sense to me, unless you're just mixing up your terms for rebound.
Old Oct 24, 2015 | 05:57 AM
  #279
kaj's Avatar
kaj
Yeah, I had it in my head backward. I just spoke with Robi last night and had a "duh" moment LOL.
I had to be reminded we're increasing rebound DAMPENING, not rebound. 😁
Old Oct 24, 2015 | 06:03 AM
  #280
mrbonilla's Avatar
hey man how much you paid your evo if you dont mind me asking?
Old Oct 25, 2015 | 06:40 PM
  #281
kyoo's Avatar
hey all! just did my first PDX event!!! It was AWESOME! I see the appeal lol. It wasn't even on a popular track (GMP) but it was still a blast. I only got three sessions in (girlfriend got in a car accident, all fine, pretty minor) but I improved every session, especially between 1-2, and my instructor said I was easily the fastest guy in the novice group - though he admitted that wasn't saying much lol. I only waived one guy by the entire drive (2nd session), and we were about even but my instructor wanted me to have someone to chase.
I think I genuinely improved as a driver through the process. Such a different sport compared to autocross - some clips below, including autocross today - note the difference in driving lol
Old Oct 25, 2015 | 07:46 PM
  #282
kaj's Avatar
kaj
Hard-core autox guys (at least the ones in my area) will swear we're crazy, but IMO track days > ANY day of the week. 80-100mins of seat time vs 5? Hell yes.
And I'm with you: I was dead hooked after my very first one. I've never looked back.
Old Oct 26, 2015 | 06:47 AM
  #283
kyoo's Avatar
ha - usually the stereotype is the RR guys think the AX guys are the crazy ones.
now that I've done I definitely see the merits for both and will continue doing both for sure. RR is hands down more dangerous though lol. there's something very awesome about pushing the car to the limit at AX and not worrying about spinning out or hitting anything, and driving a different course every time.
few updates:
sent in oil samples for 10w30 ZROD with about 40 runs autox, and one with about 60 min PDX time - will update when I get those back. The Redline MT85 is shifting very smoothly, but still has a lot of trouble getting into 1st and R, even after I adjusted the clutch. Hoping that gets better over time - otherwise, any ideas?
I think if these clutch plates ever wear out I will get the SD plates (as opposed to HD) for a little better livability.
After I finish off this last case of ZROD (testing Amsoil filter, Fram Ultra, and Pure1) will give Redline a try with whichever oil filter gave the best UOA of those 3. After I finish off the Diaqueen I will give redline or motul a try for the t-case and rear diff.
Old Oct 26, 2015 | 01:40 PM
  #284
kaj's Avatar
kaj
I think tossing the car around at AX is a lot of fun, that's why I do it. I also think it helps on the road course. You get so used to processing info and reacting quickly that the road course seems almost slow-mo. Definitely beneficial to each other.
Just saying that if I could only choose one.....
Old Oct 26, 2015 | 09:08 PM
  #285
kyoo's Avatar
thankfully we don't have to choose just one! you're lucky to be in cali though - my season is just about wrapping up now...
