razorlab's simple build(s)
Old Jun 7, 2021 | 01:14 PM
  #1651
LetsGetThisDone's Avatar
Very nice. My car needs a brake upgrade, need to bring myself to drop the cash lol
Old Jun 7, 2021 | 01:34 PM
  #1652
RazorLab's Avatar
For the CT9A, look at the AP Racing kits as well. They are supposed to be great. I was actually looking to do that with my CZ4A but they didn't have any proven kits for the platform at the time.
Old Jun 7, 2021 | 05:20 PM
  #1653
Essex Parts has the 4 pot kit that clears 17" wheels, or the 6 pot kit with 372mm rotors that is $4500. I can get stop tech through turn14 at a significant discount through my shop. So I'm leaning that route.
Old Jun 20, 2021 | 07:17 PM
  #1654
RazorLab's Avatar
Evo made it the 90 miles from NJ to our new house in NY.
The most it's driven in two years. Only issue is that the fuel pressure got stuck at 62-64 psi at idle and cruise which made some bits of driving in traffic a little interesting and I also couldn't give it much throttle as the car felt really unhappy. So I just cruised in the slow line while my wife followed me.
Going to guess maybe the fuel filter got clogged or something similar. Going to pull the filter when I get some time. Right now we are tripping over boxes and furniture.
New garage is bigger but needs some TLC.
Old Jun 21, 2021 | 12:27 AM
  #1655
Bobmugen's Avatar
Was there a big difference when you upgraded to 6 piston big brakes? You plan on upgrading the rear?
Old Jun 27, 2021 | 09:33 AM
  #1656
RazorLab's Avatar
Pulled the inline filter out today. Totally clean with no blockage. So I guess I need to pull the radium hanger that I literally just put in, out of the tank, and see what's going on. My surge tank is not showing any pressure so I doubt it's anything in there. Never a dull moment with this car.
Old Jul 5, 2021 | 12:51 PM
  #1657
RazorLab's Avatar
Didn't work on the car to figure out the fuel pressure issue but I did work on the garage that the car sits in. We just bought a house in the mid-hudson area of New York and the 55 year old garage slab has seen better days.
It was either pay a crazy amount of cash to demo and pour a new slab or try out some tiles to hold me over until I pay for a new slab. I ended up ordering half the amount of tiles to see if it would work well with the floor condition and I would happy with the outcome.
I installed them today and I have to say it is way beyond my expectations. I was so impressed I ordered the other half the second I finished the work today.
Old Jul 6, 2021 | 04:02 PM
  #1658
ctfpevoVIII's Avatar
looks great goes nice with the color of your car! What did it cost to do that side of the garage and where did you buy?
Old Jul 6, 2021 | 05:11 PM
  #1659
RazorLab's Avatar
Thanks!
That bit, which is a little more than half of the garage, was 290 tiles and it cost $800.
Overall, it is going to cost right about $1400 to do the whole 24'x21' garage.
I purchased them from Garage Flooring LLC. I am 99% sure these are the same as Racedeck. They even came in racedeck branded boxes.
Old Jul 21, 2021 | 08:24 PM
  #1660
RazorLab's Avatar
Figured out the high fuel pressure issue.
For some reason, when I went to tweak my pump controller mapping last month for the larger pump, it totally erased the proper map sensor scaling and I never noticed it. Put in the proper map sensor scaling and it's back to normal pressure again at idle and cruise.
Glad I checked that first before I started tearing things apart again.
Old Jul 22, 2021 | 01:17 PM
  #1661
whtrice's Avatar
Veteran: Air Force
Nice, about time you had a simpler fix for something.
Old Jul 22, 2021 | 03:35 PM
  #1662
RazorLab's Avatar
Welp, not so simple. I took it for a spin today and it's not increasing fuel pressure in boost. I am also getting a weird signal from the map sensor when I calibrate it through the torqbyte software. HOWEVER, the map sensor is logging perfectly fine in racecapture and in spec with my OEM sensor so I don't think it's the sensor itself.
So now I am thinking there is some connection problem with the 0-5v line from the map sensor to the torqbyte controller. I swear it's never-ending with this car. I literally haven't been able to just enjoy this car in like 3 years. Redonkulious.
Old Jul 22, 2021 | 06:49 PM
  #1663
whtrice's Avatar
Veteran: Air Force
Oh crap...I thought you'd be off to the races. Sounds like an electrical gremlin now. You proved it isn't the MAP sensor by logging. The torqbyte controller and or connections? Since software was the previous issue is their another setting that could be compromised as well?
Old Jul 22, 2021 | 07:47 PM
  #1664
Biggiesacks's Avatar
It's always something...and oh boy aren't electrical bugs fun. The ground for the torqbyte module solid?
Old Jul 23, 2021 | 09:20 AM
  #1665
RazorLab's Avatar
Went to go get the Evo inspected today. It passed which is good so now I can actually drive the car when and wherever I want.
The odd thing is now the car runs just fine, increases fuel pressure in boost and everything. *shrug* If anything, now it's about .7 richer at WOT, which doesn't sound crazy as I went from the 450 to the 525 pump.
I forgot modded cars can be temperamental. I just don't like having a high horsepower car run so temperamentally... I Will still dig into things to make sure everything is 100%.
Also, I forgot how crazy fast this car is, even on 24psi, which is 100 whp down from my 29psi map. lol.
