CT9A Resurrection and Innovation
Old Aug 31, 2016 | 05:49 AM
  #361
Epyon's Avatar
We neeeeeed more pictures! It's killing me to check here everyday and there's no updates with awesome goodies lol
Old Aug 31, 2016 | 06:33 AM
  #362
electron bom's Avatar
Sorry to leave you hanging
Its been very frustrating to walk by the car everyday and not have time to finish it. I visited my niece for her 1st birthday last weekend, so I wasn't able to make any progress with the build. I finally got my engine hoist back from a friend, so I now have the tools to drop the Li-ion pack in the trunk.
This is the best pic I can post for now. I should have some more interesting pics of the rear fuse box, Li-ion pack, and power cables by this weekend.
Old Sep 6, 2016 | 04:29 AM
  #363
snail's pace
I reassembled the hoist, then dropped the Li-ion pack in for permanent mounting and cable connections. Its a bit of a squeeze, but it fits. In other news, my neat ON/OFF push button failed to open the start circuit, so it had to be junked. Now I'm looking at other options to control the main contactor. More to follow shortly
Old Sep 6, 2016 | 07:32 PM
  #364
chetrickerman's Avatar
Veteran: Army
Originally Posted by electron bom
snail's pace
How much does that weigh?
Old Sep 7, 2016 | 06:19 AM
  #365
200 lbs
Old Sep 7, 2016 | 04:13 PM
  #366
IzzyRS's Avatar
I am curious to see how the weight distribution will change overall after you finish up.
Old Sep 7, 2016 | 04:28 PM
  #367
Pal215's Avatar
Me too. I should just put a fat friend in the trunk and see how it effects the car.
-pal215
Old Sep 10, 2016 | 06:21 AM
  #368
testing phase initiated
All function-test essential circuits have been constructed
Power to distribution block: check!
Start circuit energizes main contactor: check!
Main contactor closes: check!
Controller recognizes propulsion pack: check!
Unforseen start error: check! hah
Currently working on setting up a data-link to read the error code. This hardware was designed back in the days of Microsoft XP and I have Windows 7 (which doesn't have the serial communication software). The main contactor is closing, so I'm guessing the error light may have something to do with the prius hall effect pedal (which I purchased used and is a bit ragged).
My neato LED ON/OFF switch failed so I had to improvise. Here is my F1 inspired switch panel.
1/8" plywood, sharpie marker, and some cheap 20A switches
Old Sep 10, 2016 | 10:06 AM
  #369
I'm also very interested to see. Once it's roadworthy, I will put it on some corner scales. I'm keeping a full interior. Here is my present conjecture:
Starting weight MR no gas : 3220 F/R: 1964/1256 = 61%/39%
Estimated removed weight: 0810 F/R: 648/162
Estimated net weight: 2410 F/R: 1316/1094 = 55%/45%
Addition of electrics so far: 0420 F/R: 195/225
Estimated current weight: 2830 F/R: 1511/1319 = 53%/47%
Projected weight addition: 0120 F/R: 015/105
*Projected net weight: 2950 F/R: 1526/1424 = 52%/48%
*Figure assumes 276V pack, single motor setup ~250wtq.
Old Sep 15, 2016 | 08:37 AM
  #370
Epyon's Avatar
The suspense is killing me!!!
Old Sep 15, 2016 | 01:02 PM
  #371
sadly...
there is nothing of interest to report
My motor controller's error light is flashing and the Hall effect Prius pedal is not functioning. I can't read the error unless I first establish a serial connection between the controller and my laptop. I've tried several different USB-Serial adapters and several different drivers, but the best I can get is whats pictured below. I have a FTDI chipset on order, which is rumored to be the best for USB-Serial communication. Hopefully, that does the trick. I've also ordered a new throttle input. I never liked the Prius pedal.
Old Sep 15, 2016 | 01:39 PM
  #372
Epyon's Avatar
Why not get the pedal setup from a tesla?
Old Sep 15, 2016 | 03:16 PM
  #373
The Tesla accelerator pedal is nice. My issue with the OEM Hall effect pedals is that they don't match the Evo brake and clutch pedals in feel and appearance. An alternative option is to connect a Hall Effect pedal to the Evo pedal with a wire cable, but at that point I might as well be using a cable driven potentiometer.
Old Sep 15, 2016 | 09:22 PM
  #374
BiFfMaN's Avatar
I been using the Sabrent FTDI cable in windows 10 with no issues.
http://www.newegg.com/Product/Produc...82E16812156039
Old Sep 16, 2016 | 06:31 AM
  #375
bakuro117's Avatar
Have you looked into Mitsu's drive by wire setup they use on the 4g69 and 6g75 engines? Maybe it can be adapted to work somehow. The throttle pedal has a wire but it goes to an APS in the engine bay. The actual pedal feel isnt noticeably any different than my Evo. Just a thought. Might be worth checking out.
I wont clutter your thread with a pic. So here is a LINK instead.
