Tim's Evo 9 SE build. From Stock to 2.2themoon
Old Feb 22, 2016 | 02:32 PM
  #31
TheBoz's Avatar
I really want to do a 2.2 also. Thank thing is just awesome. Also thanks for all the info the wedssport wheels, I have the same set now, they look awesome.
Old Feb 26, 2016 | 08:22 PM
  #32
Abacus's Avatar
Thanks man. I'm really happy with the 2.2, good power band and low vibration. No problem on the wheels, glad you are happy with them.
Old Feb 28, 2016 | 09:36 PM
  #33
EVOFans's Avatar
TC105N are awesome wheel
Relatively affordable, light and look great
What kind of spec did you went with?18x9.5?
Old Feb 29, 2016 | 04:01 PM
  #34
TheBoz's Avatar
17x9. I was looking for a really good looking17x9 and that wheel is the win.
Old Feb 29, 2016 | 05:10 PM
  #35
Abacus's Avatar
Agree. 17x9 et35. 15.5lbs Added a 3mm spacer to clear the front brakes and running a 255/40/17 tire without any modifications to the fenders at all.
I chose the 17x9 since I like to keep rotational weight down as much as possible. This is easier on the drivetrain and makes the car a little faster. It seemed to me that a 255 sized tire was lightweight, inexpensive and all I needed for compared to anything larger.
For reference , wheel and tire on my scale is 37lbs. A stock bbs with bald 235/45/17 was 40lbs.
Old Mar 2, 2016 | 04:46 AM
  #36
EVOFans's Avatar
Is it a must to use spacer to clear the front brake?
Old Mar 2, 2016 | 10:20 AM
  #37
Abacus's Avatar
Yes with 17". IIRC the 18" does not need them.
Old Mar 29, 2016 | 05:53 PM
  #38
Abacus's Avatar
Updated 1st page with battery pic.
Old Mar 30, 2016 | 02:24 AM
  #39
vmrevo9's Avatar
Veteran: Air Force
Tim's Evo is a great example of a car that was built for numerous things! keep it up man! this thing is a beast
Im actually trying to get a hold of EFI to see if they still make the battery tray. I think my Miata battery is reaching its end and i would like to go up in size now but i need to reposition the battery. hopefully i can get one.
Old Mar 30, 2016 | 08:11 AM
  #40
IzzyRS's Avatar
Man, I am jealous of your cruising RPM at 80mph. That is awesome!
Old Mar 30, 2016 | 01:25 PM
  #41
krisdlm's Avatar
Me too!! I have a 2.4 4.11 and I have to double check but I feel like I am over 3500 cruising at 75-80
Old Apr 7, 2016 | 10:02 AM
  #42
Abacus's Avatar
I've got Evo 8 ratios and 5th gear. This is 82ish
Old Apr 29, 2016 | 05:24 PM
  #43
Abacus's Avatar
Attended the Street car takeover 4-10-16. Updated page 1
Old May 8, 2016 | 04:40 AM
  #44
Benja's Avatar
Nice work on the M130.
Did you use an off the shelf GPA/R package from Motec, or a custom package from JRR or similar?
Did RSP end up using a different idle valve such as a Bosch 3-wire instead of the factory 4 wire?
Cheers.
Old May 11, 2016 | 04:01 PM
  #45
Abacus's Avatar
Cheers.
I'm still on the Infinity. Its been too busy to put the MoTec on. Yes, its the JRR package. I've talked to John personally a few times and he runs the M1 on alot of Rally cars out west.
Factory idle valve with the 2 red/yellow wires taken out of the connector.
