Tim's Evo 9 SE build. From Stock to 2.2themoon
Old Feb 28, 2024 | 09:41 PM
  #196
Steveevo9's Avatar
Thanks for the reply Tim, much appreciated mate. The videos are epic, that car is an awesome build for anyone to follow who wants a very fast, but; versatile street car, I love it.
It’s a pity that FP hasn’t provided more details on the UHF turbo, the example is to far apart from a full bolt on car for most potential buyers to have as a reference point.
Old Feb 29, 2024 | 12:48 AM
  #197
Steveevo9's Avatar
Originally Posted by schuhie
Just going to throw this out there, I had a MHI Green on my stock block and it was a blast on pump and E. If you mostly street drive and are serious about not building the bottom end, that would be my personal pick.
I have a MHI Red on my built 9 now and its great as well. No wrong choice, just comes down to what you want.
Thanks for your input Ryan, having had both an FP Green & a Red makes your contribution valuable to others.
I have liked the FP Green for years especially once it evolved into the HTA variant. There have been many guys who have built full bolt on cars with the FP Green that have made fantastic pump gas street cars, then transitioned to E85 & increased the boost making massive torque low in the rev range & great power up top. Some of these cars have had the misfortune of destroying the OEM rods, due to the early onslaught of this addictive torque.
My turbo of choice now includes the FP Red because of Tim’s car, as it produces its torque further along the rpm range & can extend that range with much more power. The Red can also make decent power on pump & if E85 is available at a later date, a tuner can make the appropriate boost curves by gear, keeping the engine safe while producing good power & torque.
There are a few like Tim & Sean that have built 2.2 lt engines that make the Red really shine on E85, making a generally top tier street car. That’s why I think Tim’s car in this case is a fantastic example of a really powerful street car that can also produce great results on many types of track events, unlike other dyno monsters with a lot larger turbos that make their torque/power after 6500rpms or more, leaving a huge torque deficit in normal street driving scenarios.
I’m assuming your car is very similar in its torque & power to Tim’s vehicle.
Old Feb 29, 2024 | 06:12 AM
  #198
schuhie's Avatar
No problem, just figured I'd throw my opinion out there. I had the HTA Green and the HTZ Red now.
When I was on the Green and stock bottom end, we definitely limited the tq to keep the stock bottom end happy on E85 but this really wasn't an issue on pump 91 but I didn't lean on it on 91 either. It was basically a drivable gate pressure map.
Moving the tq later in the rev range and avoiding the spike certainly helps keep the stock bottom end inside the block lol.
The Red has been exactly what I wanted on the built bottom end though. It isn't quite as stout as Tim's car making only 580whp/510ftlbs but its pretty nice. But its a totally different turbo on pump vs E85 in my case. Its basically 2 different cars lol.
The main thing I liked about the Green was the spool around town on the stock bottom end. That thing spooled and picked up quick which made for a really fun street car that wasn't a high effort setup.
Old Feb 29, 2024 | 07:32 AM
  #199
Evo9isLife's Avatar
5 Year Member
My IX will always remain a stock block & most likely stay on 93 Octane as there isn’t any e85 where I live. It has just over 34000 miles, I think an FP Red would be a great turbo with the usual bolt ons.
If you want FP Red performance and reliability at 2/3 the cost I would highly recommend Art Gennari Turbo "AGT" as another option to consider. His 55mm turbo is right in line with the FP Red. Tons of dyno results and testing on his IG.
Old Mar 1, 2024 | 02:44 PM
  #200
harry wilson's Avatar
Nice build !
Old Mar 2, 2024 | 05:35 AM
  #201
Abacus's Avatar
For now,The transient response isn't nearly as good. You can see it in the dyno graph and videos. Still a neat turbo line and I appreciate his work, its just not an FP.
In today's terms " It identifies as an FP Red."
Old Mar 4, 2024 | 08:45 AM
  #202
Evo9isLife's Avatar
5 Year Member
How are you determining transient response from a pull in a single gear? If we're talking spool, its basically splitting hairs with the fp red.
Old Mar 4, 2024 | 10:36 AM
  #203
Abacus's Avatar
I've been in the game awhile.
Old Sep 12, 2025 | 06:34 AM
  #204
thepoint4life23's Avatar
I am bumping this since i was listing to a pod cast your brother did and he talked about how you used a Oil Pressure Regulator on one of your evos and that might help with crank case pressure? Is this something that you could possible talk about?
Old Sep 13, 2025 | 07:15 PM
  #205
MasterNater's Avatar
https://www.evolutionm.net/forums/ev...ochargers.html
Old Sep 16, 2025 | 11:11 PM
  #206
nightowl1985's Avatar
5 Year Member
If you have positive crank case pressure oil drain back becomes more difficult which isn't affected by oil feed to the turbo but oil returning to the pan yes if the crank case pressure is positive.
Old Sep 18, 2025 | 05:44 AM
  #207
That is helpful information. I am back to looking for new catch can set up so anything that helps is worth looking into.
Abacus
Dec 6, 2021 05:45 PM
KennyRS
Feb 17, 2018 06:32 PM
David Buschur
Jan 29, 2014 10:40 AM
KozmicMotorSpts
Apr 4, 2013 04:06 PM
antilag_200
Apr 20, 2010 04:57 AM
