Jaraxles' Build Thread (Evo X)
Old Apr 28, 2023 | 09:49 PM
  #271
Jaraxle's Avatar
Putting in the ARTEC manifold with GTX3076R gen2....
Here is a comparison of the MAP manifold vs. the ARTEC.
The MAP is just a pain to get out due to that one front passenger side bolt. Also, the LONG bolt provided by MAP (drivers rear) was completely loose. After some discussion with engineers who work in this area; MAP should have provided an alternative torquing spec vice OEM. Furthermore, it may call for a DOUBLE stack of Belleville washers.
This is because the bolt is a different material AND a different (much longer) length!!
Old Apr 29, 2023 | 08:27 AM
  #272
RobbieOh's Avatar
5 Year Member
Man, that Artec looks so sexy!
Old Apr 29, 2023 | 01:08 PM
  #273
deylag's Avatar
I recently pulled a GTX3071R Gen2 out of an Evo I am working on. The Oil Return Line was damaged and leaking. I am not sure if this rubber hose line, worm clamps, and fittings is what Garrett supplies or something the previous mechanic cobbled together. What do you have for the Oil Return line?
The long bolt supplied by MAP seems to be a regular grade 8 bolt. I dont understand their reasoning to do this. ARP makes a stainless steel M10x1.25x80 bolt. I would use that bolt instead since ARP provides a torque rating for it and SS is suited for exhaust temperature.
Long Bolt : https://www.summitracing.com/parts/arp-763-1010
Short Bolt : https://www.summitracing.com/parts/arp-773-1006
Old Apr 29, 2023 | 10:43 PM
  #274
LetsGetThisDone's Avatar
Originally Posted by deylag
I recently pulled a GTX3071R Gen2 out of an Evo I am working on. The Oil Return Line was damaged and leaking. I am not sure if this rubber hose line, worm clamps, and fittings is what Garrett supplies or something the previous mechanic cobbled together. What do you have for the Oil Return line?The long bolt supplied by MAP seems to be a regular grade 8 bolt. I dont understand their reasoning to do this. ARP makes a stainless steel M10x1.25x80 bolt. I would use that bolt instead since ARP provides a torque rating for it and SS is suited for exhaust temperature.
That oil return needs a heat sleeve.
We use ARP 8740 Chromoly bolts with OEM Belleville washers (two per bolt) and nickel based antiseize when we do a stock frame EvoX turbo. Doesn't gall on removal like stainless can. Also we haven't had the Chromoly bolts come loose like the OEM bolts tend to.
Old Apr 30, 2023 | 06:51 AM
  #275
Jaraxle's Avatar
These guys then?
https://www.summitracing.com/parts/arp-663-1006
Old Apr 30, 2023 | 09:28 AM
  #276
Monster4's Avatar
5 Year Member
I know you won't be reinstalling the MAP manifold but hopefully this will help someone else. I struggled with that bolt until I purchased an angle headed wrench. It made the job ezpz.
Amazon Amazon
Old Apr 30, 2023 | 12:31 PM
  #277
Yes. We keep 40mm and 45mm UHL on hand because the flange on the ARTEC seems to vary a bit.
And we also go with the 6pt heads like you have there, easier for crows feet to get on them.
Old Apr 30, 2023 | 12:58 PM
  #278
Jaraxle's Avatar
For the oil return garrett supplied the parts from end to end. However, yes it includes a rubber hose section (with two worm-gear clamps) to account for variance.
Old May 1, 2023 | 03:53 PM
  #279
deylag's Avatar
Thanks that is a great tip! The Chromoly bolts are both cheaper and available compared to SS bolts. I will be ordering these.
Old May 1, 2023 | 03:56 PM
  #280
deylag's Avatar
Ok good to know. The line was leaking but that might be due to damage from exhaust heat or the worm clamps not sealing around the metal pipe fitting.
Old May 7, 2023 | 11:01 PM
  #281
Lightsaber's Avatar
I second this. I too went to ARP's website to search for the M10x1.25x80 bolt, and the part number is correct:
▪ 763-1010 (12mm hex head)
▪ 773-1010 (12mm 12pt head)
Old May 9, 2023 | 07:44 AM
  #282
harry wilson's Avatar
Great build ! keep it up
Old May 14, 2023 | 09:54 AM
  #283
Jaraxle's Avatar
It is a SNUG fit in there!
Goal is to get her out and running within 6 days!
Old May 15, 2023 | 06:40 PM
  #284
Jaraxle's Avatar
Now for some cool stuff.
The idea with the CLOWN filter was to prepare tuning and fitment to allow a full 4" to the inlet on the garrett turbo. This is finally happening:
ACTION PRINT LINK VIDEO:
https://photos.app.goo.gl/CkNsHGVsnnT5c3ns5
and the result was great:
Old May 16, 2023 | 08:25 AM
  #285
RobbieOh's Avatar
5 Year Member
So cool!
