Jaraxles' Build Thread (Evo X)
Old Jul 24, 2023 | 07:29 AM
  #316
RobbieOh's Avatar
5 Year Member
So Ohlins and RPF1s are on my to-do list over the next two years. Ohlins first, but I plan to run something like 3.5* camber up front and 2.5* out back, starting out then going from there based on tire wear, but this will be autox setup.
Old Jul 26, 2023 | 06:57 PM
  #317
Jaraxle's Avatar
Assembly completed!
Old Jul 27, 2023 | 06:40 AM
  #318
RobbieOh's Avatar
5 Year Member
Beautiful! What rates did you choose? Also, I see that it looks like the top bolt hole is not oval'd like the oem strut or is that just the pic angle?
Old Jul 27, 2023 | 06:24 PM
  #319
Jaraxle's Avatar
MIS Mi10S1 includes spherical upper mounts.
MIS Mi10S1 has a target ride height reduction of 25mm front and rear.
MIS Mi10S1 front spring rate: 100 N/mm.
MIS Mi10S1 rear spring rate: 80 N/mm.
I set them to 27mm front and rear drop to start.
Old Jul 27, 2023 | 06:26 PM
  #320
Jaraxle's Avatar
Low boost, low timing initial results....
Old Aug 10, 2023 | 06:09 PM
  #321
Jaraxle's Avatar
So got around to installing the Ohlins and Oh-MY, I should have bought these SOOO much sooner.
She sits nice (not like a pickup truck), and since I'm not running it in SNOW anymore, I can be this low and leave it that way.
I need to look up what a good middle ground (between street and track) setup would be for camber and toe since I now need a new laser alignment.
Old Aug 11, 2023 | 07:44 AM
  #322
Construct's Avatar
How often do you plan on tracking the car?
Multiple track days or even a lot of autocross events will eat the tires quickly. When I was doing some partial-DD with a few track days per year I found it best to go all in on the track alignment. The wear from street use was minimal relative to the 160 minutes of track driving I could get on a single weekend. I was also going through 1-2 sets of tires per year, so YMMV.
Old Aug 11, 2023 | 05:20 PM
  #323
Jaraxle's Avatar
I only do a handful of events a year. Five max I would say, but I am curious what your alignment setup numbers were. I am looking to burn these tires up, and get the Re-71rs back on there. I just cannot believe the level of fender roll that appears to be needed for these RPF1 +15s.
Old Aug 12, 2023 | 08:23 AM
  #324
Construct's Avatar
Five weekends at the track could be enough to consume a set of 200TW tires depending on how many sessions you run.
I think I ran -3.2 camber up front when I was doing some double duty.
As for the fenders: Get camber set first. Each degree of camber is going to move the top of the tire inward about 0.22". Two additional degrees of camber will pull it in almost a half inch.
The tire will also tuck inward as it moves up. You'll have to manually move through the suspension stroke with the spring removed to see it.
Old Sep 10, 2023 | 06:35 PM
  #325
Jaraxle's Avatar
Took the RPF1's off after only 100 miles on them. I am not willing to roll the fenders as much as what appears to be needed.
So if anyone is interested - pretty much brand new; box and covers included...etc...
The RE-71RS rubber will get moved to the gold Konig wheels on there now.
I'm burning up the pilot super sports tomorrow at NY Safety Track.
Old Feb 2, 2024 | 07:11 PM
  #326
BenMara's Avatar
5 Year Member
Keep up the great updates. I'm still in the planning stages of my EvoX MR... Incorporating a lot of your ideas and results into my build.
Old Feb 12, 2024 | 05:01 PM
  #327
Jaraxle's Avatar
Wow - I wasn't sure anyone was reading my stuff these days. If you have any questions, just post them here. I have learned a lot of lessons (some the hard way) and I hope my thread helps people with their build!
The car isn't done, she is just sleeping for the winter. She will continue to go through EVOLUTION and eventually will make it to my vision for the final form....
Old Mar 28, 2024 | 06:25 PM
  #328
Jaraxle's Avatar
Just remember the weakness of the TC-SST is OVERHEATING. There is some glue holding a magnet on the shift forks. If the trans is allowed to overheat, that is what damages it.
Invest UP FRONT in massive cooling and my experience that with tranny fluid changes every 20kmi you can beat the heck out of the trans and it can take it. Torque holding can now even be increased with a TC-SST reflash (which I did).
Old Mar 29, 2024 | 12:42 PM
  #329
RobbieOh's Avatar
5 Year Member
I'm looking to upgrade the oem cooler to a setrab unit, hopefully over the summer.
Old Mar 30, 2024 | 10:18 PM
  #330
BenMara's Avatar
5 Year Member
Right now im debating on getting a tune b/c I had to upgrade my IC due to a road gater incident. I purchased the car with a cobb dongle. but no idea who to trust.
