3rd Build, lets hope this is the final...Evo8
Old May 23, 2022 | 11:34 PM
  #106
yellowevo82's Avatar
Keep plugging away don't give up its probably something small. Sorry to hear about all your bad luck. Good luck with it all.
Old May 25, 2022 | 09:32 AM
  #107
blackline's Avatar
5 Year Member
New rad cap coming in today,
Thanks man
Old May 27, 2022 | 05:48 AM
  #108
blackline's Avatar
5 Year Member
I think I may have resolved the issue.
fore I installed the new OEM radiator cap, I decided to unplug the hose from the radiator to overflow and blew through to confirm it's clear, it was clear. Then I plugged the hose from the overflow and blew through it, guess what, it was clogged with rust/gunk. This is the reason it pop that hose off while on the dyno as it didn't have a path to expand. I installed the STM coolant tank I had sitting and now the temps are pretty much good. Temp doesn't go past 196ish, but when it does, it drops quickly. The radiator feed line seems to still have some pressure in it but I'm thinking it's normal.
Old May 27, 2022 | 06:07 AM
  #109
TimInselman's Avatar
My radiator hoses always seem a lil firm once the car warms up. Glad all seems to be well with it now. Time to enjoy it now.
Old May 27, 2022 | 08:37 AM
  #110
black_out's Avatar
Your radiator hoses will always have pressure when warm. You have a 1.3 bar cap so it'll always have up to 1.3 bar before the cap will vent.
Old May 27, 2022 | 09:29 AM
  #111
blackline's Avatar
5 Year Member
ok cool
gotcha, I had a 1.3 cap but switched to the OEM 1.1bar cap yesterday.
Old Jun 6, 2022 | 05:28 AM
  #112
blackline's Avatar
5 Year Member
coolant issue seems to have been resolved.
buttttt, now the car doesn't want to idle now, smh. cold start is fine but after it warms up it doesn't want to idle. Tried changing target RPM to but doesn't seem to do anything. Going to have to dig through the bay and see if any hoses came loose.
Old Jun 6, 2022 | 05:46 AM
  #113
staywide8's Avatar
Check idle duty percent compared to whats needed. May need an adjustment threre.
Old Jun 6, 2022 | 06:29 AM
  #114
blackline's Avatar
5 Year Member
I'll check that out. It was idling fine before but then stopped. well, thinking about it, it would idle at target then idle around 5-700rpm higher than target after running for awhile, now it's doing the opposite. lol
Old Jun 6, 2022 | 03:31 PM
  #115
CurseDSM's Avatar
Just give it a kick and tell her to stop being stupid lol.
Old Jul 18, 2022 | 08:22 AM
  #116
blackline's Avatar
5 Year Member
Got another tune day set for next week. Alpha from Induction Performance will be tuning it now.
Switched from a GM IAT to Rife IAT as that's what alpha recommends.
Old Jul 18, 2022 | 09:03 AM
  #117
staywide8's Avatar
Any reason why on the iat sensor?
Also, any reason on switching tuners? Not happy wiht results?
Old Jul 18, 2022 | 10:22 AM
  #118
CurseDSM's Avatar
Idk why he would have you change the iat sensor they are all pretty much the same thing. Scaled slightly different.
Old Jul 18, 2022 | 10:43 AM
  #119
blackline's Avatar
5 Year Member
Based off my research, it's suppose to be faster and more accurate.
Nothing wrong with the previous tuner, just wanted it tuned with alpha
Old Jul 30, 2022 | 06:43 AM
  #120
blackline's Avatar
5 Year Member
Well, here’s what happened.
car made 792hp/650tq @ 42psi on e75. Had to stop because it started to drop fuel pressure up top. Guessing the dual 450s and stock fuel lines held it back. Going to upgrade the lines and pumps in the winter and go back.
dialed the car back to 38psi to keep things safe. Still seems like a torquey street monster.
