Valve seals or turbo seals? White smoke & oil burn smell
Old Jul 27, 2017 | 12:47 PM
  #136
Bmurray's Avatar
That shouldn't reoccur so quickly after new seals. Was the head removed and guides inspected when the seals were replaced?
Yes everything checked out according to my tuner &I installer.. He doesn't know why they would be leaking agaon already
Old Jul 27, 2017 | 01:00 PM
  #137
That sounds questionable.
Old Jul 27, 2017 | 01:05 PM
  #138
Bmurray's Avatar
He said he would go through and replace the seals again. Is it possible for the machine shop to pinch a seal or anything like that when installing them causing it to not seal correctly?
Old Jul 27, 2017 | 01:55 PM
  #139
I'm not looking at it, so it could be many things. Improperly installed seals, damaged valve guides, damaged valve stems, worn valve guides or stems. I don't recall if you upgrade your valve springs last time. If you didn't, you could be getting valve float, and retainer to seal contact. If you did, ensure you're using the correct retainer for your retainers. IIRC the supertech duals require the use of their seals.
Old Jul 27, 2017 | 06:17 PM
  #140
Bmurray's Avatar
When we replaced the seals, we did GSC beehives with the Ti retainers
Old Jul 27, 2017 | 11:38 PM
  #141
RightSaid fred's Avatar
Did you forget to check the pistons while it was apart?
It's getting worse?
Post no 24.
Old Jul 27, 2017 | 11:58 PM
  #142
RazorLab's Avatar
It's getting worse?
Post no 24.
But her fuel pressure
Old Jul 28, 2017 | 02:10 AM
  #143
That's why mine, with 165psi of compression , and 7%-9% leak down made my turbo smoke like a freight train, because the engine was broken...
So yours is broken and it's got a cranking compression of 165?
The OPs isn't broken, it's the turbo and it's got a cranking compression of 120?
That makes sense.
Old Jul 28, 2017 | 02:09 PM
  #144
Bmurray's Avatar
VC is off and I just dropped it off to have a 10an welded on to my ets intake, and then have the cover tapped and drilled as well.
Inspecting the seals and everything "looks" normal to me.. Is there anything I should look for? (In reference to the valves still having oil on them)
Old Jul 28, 2017 | 02:28 PM
  #145
Its hard to inspect them with the valve springs on, but you can make sure the spring is still on the seal, and look for any tears in the seal, or evidence of marring/galling on the valve stem.
Old Jul 28, 2017 | 06:31 PM
  #146
Bmurray's Avatar
Got the turbo off to send to FP. Couple pics
Old Jul 28, 2017 | 07:32 PM
  #147
Where's the oil ?
Old Jul 28, 2017 | 07:41 PM
  #148
Bmurray's Avatar
Where's the oil ?
Compressor blade is coated as you should be able to see and there's oil all right behind the turbine..?
Old Jul 30, 2017 | 10:07 AM
  #149
Bmurray's Avatar
Just one of those curiosity questions. I'm doing the 10an valve cover vent regardless.. but how do several 8,9 second evos (my tuner included) run stock size pcv vent lines, or just a breather filter on the vent with no crank case pressure issues?
Old Jul 30, 2017 | 10:26 AM
  #150
gsrboi80's Avatar
They don't run FP bb stock frame turbos.
