Evo X Electrical / Audio / Security Discuss electrical and audio system upgrades or alarm configurations.
Evo X Battery not charging
Old Aug 10, 2021 | 01:59 AM
1brishimov's Avatar
Hello fellas,
I am writing with an issue I am currently having with my car.
Story is as follows:
After staying for 5 days in my garage, I started the car and the battery light on the dash was turned on. After 10 seconds, the light turned off, then after another 10 it was on again.
This repeated several times with different intervals, until it was permanently on. After driving for a bit, it flashed ABS warning, which led me to believe that either my battery was dying or it was not charging.
I stopped the car and turned on my battery charger overnight.
Next day, on fully charged battery, light is still up.
Then it appears it should be alternator.
I took it off and sent it to a professional to review it.
They said that it works just fine.
Now all is assembled, but it appears my car does not want to set the command to charge the battery.
Currently, when key is in ACC, I do not see the battery light and when car is started there is no battery light either.
At the same time the alternator is not charging the battery.
Any ideas where should I look?
Old Aug 10, 2021 | 11:29 AM
splattj's Avatar
Check the white 3 wire connector on the alternator. If it's on tight, take it off and check the condition of the connector as well.
Check the fuse at the positive battery connection. It is the 100 Amp fuse.
There is also a 7.5 Amp fuse under the dash in that fuse box. This is the fuse that is for the ignition on trigger for the armature in the alternator.
Old Oct 22, 2021 | 01:38 AM
1brishimov's Avatar
Been a while, but it finally turned out to be ground connection that was failing. All fixed!
Old Aug 5, 2024 | 10:18 PM
awauto's Avatar
Hello, I understand its been 3 years since the last reply on this post. I'm having this same issue. Which ground was it exactly that solved your issue?
Old May 19, 2026 | 07:26 PM
jroc123's Avatar
do you know what ground was causing your car to do this ? My car is doing the same thing
Old May 19, 2026 | 08:00 PM
jroc123's Avatar
what ground was it ? Having same issue ? Was it in the cabin or on the main harness in the engine bay ?
Old May 20, 2026 | 11:22 AM
RobbieOh's Avatar
5 Year Member
OP hasn't logged in since 2021, so don't count on them answering.
Old May 20, 2026 | 06:07 PM
jroc123's Avatar
yeah wish there was a way to get a hold of them lol could save me a lot of time lol
overdrive1
Jun 1, 2022 08:54 AM
waid302
Apr 7, 2015 08:13 AM
roblaza
Jul 16, 2012 01:45 PM
outlaws69
Northwest Region
26
Nov 3, 2010 08:42 PM
Noe18
Aug 18, 2007 07:01 AM
