ALABAMA.. who is all here?
FWIW, Cesar ran a 11.8 w/o E85. He was on around 96 octane fuel, but stock injectors/turbo/cams/etc. That's not even a ported 10.5 ... all stock.
And I say bring it ... Evo's might be best from a dig, but they can roll too. You've got other things working against you, even if you want to run from 70+ like your friend to get rid of traction issues.
Actually, that's all it takes ... my car is intake, LICP, FMIC, exhaust mani, O2 housing, TBE fuel pump, injectors and tuning. So, intake, exhaust and fuel. It was 11.9 capable before the fuel change.
i do believe your running alot more boost then stock, and you have alot more then just an intake and exhaust(intake, LICP, FMIC, exhaust mani, O2 housing, TBE fuel pump, injectors) <-- to be exact, and your no longer on 93 either. once you change all those main feeatures of the the car, your not a 'lightly' modded evo.. if u were still on stock boost and 93, i might agree with you.
thats not what i call a 'lightly' modded car.. thats a heavely modded stock motor stock turbo car.
and your an idiot talking about hank racing a MOTORCYCLE from a 70 kick when (bike rider) requested faster and agreed to the 70mph speed vs a 4300lbs GTI and they took it up to 160+ mph.. u go race hank from a dig.. o wait.. whats your excuse again? bad clutch.. get it fixxed or dont talk.
dont say bring it when you have backed down in the past
haha.. u got me on that one.. but how fast did you go with the origonal motor? im assuming of coarse its not the same model motor anymore..
It is built, but I'm in need of a ring job, and a clutch, so I'm going ahead and taking some precautionary measures while I have it out and check the bearing clearances, gaskets that I can't normally see, etc...
it's not my daily, so I can afford to have it down for a bit.
we set one up that had completely stock internals and it went 11.9. It's still running around. Stock head, a mild cam, oem turbo manifold.
matt, your way off base. i said its not just an intake and exhaust.. aka.. filter, and cat back, and retuned for those parts.
And I have never backed down from racing Hank or anyone else. You are right, I won't race from a dig because my clutch is weak, but I offered to race from a roll and never heard back. That's even giving up my main advantage.
If I happen to run in to Hank one day on an empty road, we'll see what happens. I won't run him from 70 to 160 though ...
this is starting to get ****ing retarted!!!! take it to the ****ing track or shut your ****ing mouths!!!!!!!!!!!
nobodys car is 100% right now, and it winter anyways! so why all the **** talk!?
I wasn't trying to single any particular person out, it was a general observation. my clutch can't hold instant torque, rolling torque, NA torque, or anything else for that matter. if I'm swooft this afternoon I might have the transmission most of the way out by dinner time.
