GT3071 dyno results
Old Jun 19, 2005 | 08:48 PM
  #211
statix's Avatar
Originally Posted by Dustin@Vishnu
It is actually much different than the ATP adapter. Instead of redoing the whole hotside, we use the factory garrett housing, which bolts to the adapter. The result is a fast spool, and power numbers that are somewhat close to full manifold turbo kits.
Right, I realize your using the factory housing, but the adapter basically is what ATP already uses with there housing.
So basically they are both going to have the same flow characteristics, rather than the exhaust flow straight down into the turbine, it has to flow down and back to the turbine...
Old Jun 19, 2005 | 09:32 PM
  #212
Dustin@Vishnu's Avatar
From what we have seen, the reason the ATP kit has spool issues isn't because of the way the exhaust flows, but rather the tolerances between the housing and the turbine wheel. So yes, more power can be obtained with a manifold, but the spool is somewhat similar to that of a manifold equipped car.
Old Jun 20, 2005 | 05:12 PM
  #213
wthoevo8's Avatar
What kind of dyno does Turbo XS has???
Originally Posted by Eclipsed Evo
Oh ok. I was thinking maybe my 37 was a 71 there for a minute. Any chance you will be selling that adapter by its self and maybe the downpipe too? I have the ATP 3037 kit and not real thrilled about its spool up. I did get get 364whp yesterday at turbo xs but its kind of a dog down low.
BTW that kit looks very nice.
Old Jun 20, 2005 | 06:53 PM
  #214
Noize's Avatar
EvoM Administrator
The highest reading Dynapak in the country. A stock Evo made like 255whp there.
Old Jun 20, 2005 | 07:11 PM
  #215
Its actually a dynamic testing system, but they input a 400% humidity factor to make it read like a dynojet. and who could forget about the the temp probe.
Old Jun 20, 2005 | 07:15 PM
  #216
Drews_WRX's Avatar
that should be good for high 11s.
Old Jun 20, 2005 | 07:21 PM
  #217
Noize's Avatar
EvoM Administrator
XS Engineering has a Dynamic Testing System, TurboXS has a Dynapack 5000. I saw he put TXS above, so I assumed that was the dyno he meant.
Old Jun 20, 2005 | 08:02 PM
  #218
wthoevo8's Avatar
Does these dynos read higher than the Vishnu one???
Old Jun 20, 2005 | 09:53 PM
  #219
Jaylenospoolboy's Avatar
Every dyno reads higher than Vishnu's!
Old Jun 21, 2005 | 11:22 PM
  #220
EricR's Avatar
Just curious, how do you think an AMS 3071 kit will compare to Vishnu's offering with the cast adapter?
Old Jun 22, 2005 | 07:39 AM
  #221
Ludikraut's Avatar
AMS kit should provide earlier spool-up ... along with a painless upgrade path to a gt35r
I'm waiting for mine to be installed, hopefully I will have dyno numbers next week.
l8r)
Old Jun 22, 2005 | 09:20 AM
  #222
l8r)
You can put a 35R on the Vishnu kit too. It can take the full GT series.
As far as spool-up, there is less exhaust gas to be pressurized in the stock manifold since it is shorter, so we might see very similar if not earlier spool ups on the stock manifold.
The only thing that might slow the spool would be the angle that the collar forces on the exhaust before the turbo.
On the bigger turbos, an extrude hone on a stock manifold might add a couple of hp IF the stock manifold creates a choke point.
Old Jun 22, 2005 | 09:26 AM
  #223
l8r)
BTW, turbos show spool at different RPM on the same car, so be careful making a comparisons with Dynojets, Mustangs, Dyno Dynamics... .
Should be 2 kits, same or similar cars on same dyno imho.
Old Jun 22, 2005 | 10:28 AM
  #224
Ludikraut's Avatar
I was under the impression that a tubular exh. manifold flows better than the stocker, providing more hp and better spool ... wasn't that the selling point of the original Vishnu stage 3 vs. stage 2?
l8r)
Old Jun 22, 2005 | 10:40 AM
  #225
4G63>OOOO's Avatar
A tube header will be better at high RPM, provided the primary runners are long enough, but spoolup is better in a cast header.
