GT3071 dyno results
Old Jun 22, 2005 | 10:54 AM
  #226
Jaylenospoolboy's Avatar
Originally Posted by Ludikraut
I was under the impression that a tubular exh. manifold flows better than the stocker, providing more hp and better spool ... wasn't that the selling point of the original Vishnu stage 3 vs. stage 2?
l8r)
Yes it was, but it turned out to be a turbo issue not the manifold.
That's why this set up got 356 whp on pump on 91 WITH A CAT. in comparison, the stage 2 with the 3071 and a cat on 91 octane would make around 300 whp at a later RPM and drop dramatically at the redline.
Essentially, that is what this collar tested for. It was either the turbo or the manifold and it turned out to be the stage 2 turbo set-up that was introduced last summer, not the manifold.
For the money, the stage 2 is still a phenomenal set-up and will still lay the wood to most supercars.
BTW, the stock manifold looks like it can flow fine to the redline with the 3071. Check out the page one graph. Dunno about the 30R, 35R, but I suspect we will be surprised. We'll all know by the end of the summer. It might be the tubular manifold is overkill.
Old Jun 23, 2005 | 05:54 PM
  #227
Taz's Avatar
Taz
Looking at the pics it seems the downpipe will run awfully close to the a/c compressor. Maybe the adapter could be made to move the turbo a wee bit further to the drivers side?
Old Jun 23, 2005 | 10:14 PM
  #228
I can't see anything from these pictures that looks that close to the compressor.
A little heat wrap on the downpipe should make this kit quieter, cooler (if it is near the A/C), and even more stealth.
Old Jul 9, 2005 | 10:00 AM
  #229
EVO-00X's Avatar
Talking Gt3071
Hi guys (from Australia) - I've been paying particular interest to this thread as its been a wealth of information with some great proven results on the GT3071. I just purchased one of these GT3071R-WG turbos from ATP (pic on left) with the internal wastegate instead and running the T25 flange. specs here: http://www.atpturbo.com/Merchant2/me...egory_Code=GRT
I did some searching and discovered these are identical specs to the HKS GT2835R in every way. Same housing sizes, wheels, trims, and A/R, but less than half the cost!
Has anyone bought any of these yet and tried them out with internal WG setup?
PS: Our pump gas here is 92, 96 and premium 98 octane, and I'm looking forward to finally bolting up one of these suckers to my car along with some other mods...
Keep up the good work. Will pop in often to see how thngs are going...
Old Apr 7, 2006 | 05:07 PM
  #230
EvoG8r's Avatar
Would the adapter bolt on to a 50 trim turbo, like the one PTE makes?
Old Apr 8, 2006 | 04:55 AM
  #231
andrew20195's Avatar
Note: I believe Australia uses RON for octane, so if you want to compare to U.S. octane numbers, you will need to subtract 5 from each, i.e., 87, 91, and 93.
Old Apr 9, 2006 | 04:02 PM
  #232
broddey's Avatar
Ok, if I run a 35r with your adapter kit and XEDE/SMART set with methanol on a IX with a 280 cam and no cat, what is the realistic spool rpm?
Is a 35r a little too big for my application, and should I consider the 3071 or something similar?
I am looking for an everyday 500hp car that can clean up at the drag strip and the race track.
Old Apr 9, 2006 | 04:05 PM
  #233
scorke's Avatar
What is too much spool time for you to lose. A gt35R on a 2.0 can be expected to make 20-22psi anywhere between 4200-5k.
Scorke
p.s. If your looking for an everyday 500hp, you shoulda gotten a z06
Old Apr 9, 2006 | 07:08 PM
  #234
A 35R is too big for the Vishnu adapter kit. The 30R is the biggest GT turbo that will fit.
Old Apr 9, 2006 | 08:58 PM
  #235
Vishnu_Evo8's Avatar
my stage 2 makes full boost @ 4300-4400 rpm in 3rd gear. (with a garret 30r or 3037r) And it makes full boost @ 3700 rpm in 5th gear.
Old Apr 10, 2006 | 07:08 AM
  #236
mmoranda's Avatar
Thats got to be a bit scarry when you hit boost at that speed.
Old Apr 10, 2006 | 07:13 AM
  #237
Smogrunner's Avatar
It is scarier for me in the lower gears.
Old Apr 10, 2006 | 07:14 AM
  #238
Ted B's Avatar
I wouldn't go so far as to call that "scary".
Now, this IS scary:
http://www.dpccars.com/car-movies/02...abusaTurbo.htm
Old Apr 10, 2006 | 07:54 AM
  #239
3deep's Avatar
With all the stg 2's out there has anyone else hit 360 on shivs dyno w/91 oct.
Old Apr 10, 2006 | 01:31 PM
  #240
trinydex's Avatar
Now, this IS scary:
is it me or is that turbo bigger than the engine in the bike?
