GT3071 dyno results
Old May 19, 2005 | 07:59 PM
  #166
EVOtook's Avatar
Originally Posted by shiv@vishnu
By popular request, this kit will go into product with the cast stainless steel adapter. Once we have final pricing, we'll make an announcement here and take pre-orders since we're only going to make a limited first run of the cast adapters. This kit can be ordered with a 3071, 30r or 35r. It will include a downpipe which mates up to your cat-back. It will also look completely stock once you bolt on your heatshield
Cheers,
Shiv
Is this weeks or months away?
Old May 24, 2005 | 11:15 AM
  #167
SuPeRNeT's Avatar
what does the a/r on the turbo represent? what one is better?
Old May 24, 2005 | 04:30 PM
  #168
andrew20195's Avatar
Area/Radius ratio of the turbine housing. Basically, with the same compressor side, a larger a/r = higher high rpm boost, and less exhaust manifold pressure, while a smaller a/r = lower boost threshold, but the turbo may "run out of steam" so to speak at higher rpms.
Which one is better depends on what you want.
Old May 24, 2005 | 06:50 PM
  #169
bonestockevo8's Avatar
count me in
Old May 24, 2005 | 09:33 PM
  #170
LT1runner's Avatar
count me in too.
Old May 25, 2005 | 07:19 PM
  #171
alex_alex's Avatar
count me in on a gt30r please hurry
by the by, is this a 3037s?
Old May 25, 2005 | 07:43 PM
  #172
Dyno4mance's Avatar
That is correct Alex...
Old May 28, 2005 | 12:53 PM
  #173
alex_alex's Avatar
what is the deal on this turbo? seems like a few companies are saying this turbo is an HKS specific turbo. I know that HKS has its own kit out, but they make it seem like it isn't a true Garrett turbo like the 3071/35r, etc.
i know the one Vishnu carries as a different AR, but
Old May 28, 2005 | 02:20 PM
  #174
trinydex's Avatar
the 3037s is the hks spec turbo made by garret... it is similar to the 3076 with a slightly different comp wheel size i think....
Old May 28, 2005 | 02:33 PM
  #175
Smogrunner's Avatar
All I know is that the 30R IE has in his V stage 3 makes big power and has very acceptable spool. Call it what you want, but I haven't seen a 30r signifcantly outspool it yet AND it made 494whp and 432ftlbs.
Old May 28, 2005 | 02:57 PM
  #176
Obsoleteasian's Avatar
INteresting.
Old May 28, 2005 | 03:02 PM
  #177
Ron's Avatar
Ron
The only difference between the HKS GT3037 and the Garrett GT3076R is the turbine housing-- HKS puts their own housings on Garrett's turbo. The HKS housings have a smaller inlet flange (its a T25 flange) while the Garrett housing has a T3 inlet flange.
The genuine Garrett housings are 0.63, 0.82, and 1.06 A/R. Not sure what the HKS housings are, but they're all on their website.
Old May 30, 2005 | 12:21 PM
  #178
nickracer9's Avatar
the gt3037 has a 55lb/minute compressor vs. the 3076 52lb/minute compressor. correct me if i'm wrong.
Old May 30, 2005 | 12:55 PM
  #179
Drews_WRX's Avatar
I second that. I drove IE's car, and it is a beast....of course it takes awhile to spool, its a big turbo, but it only takes a bit longer to spool than the stocker, and once it hits, look out.
p.s.-you going to let me drive your car smoggy?
Old May 30, 2005 | 12:58 PM
  #180
Smogrunner's Avatar
HELL NO
