Dyno Results - HKS 280 + Methanol
Old May 9, 2005 | 08:27 PM
  #106
EVO8LTW's Avatar
Originally Posted by Ted B
That depends on your rate of injection and how often you're boosting enough to activate the injection.
With my setup, the IC sprayer reservoir will last 5-6 1/4 mile passes or so, maybe more.
5-6 1/4 mile passes would be only about a minute or so of WOT time! Does it really run out that fast?
Old May 9, 2005 | 08:29 PM
  #107
Ted B's Avatar
That depends on your injection unit.
Mine delivers about 1000cc/min. I don't know off the top of my head the capacity of the IC sprayer bottle, but it's very simple math to determine how long to depletion.
Old May 9, 2005 | 08:31 PM
  #108
jj_008's Avatar
With my Aquamist system running a 1mm nozzle it will empty out a 1 liter bottle in about 20 seconds.
On the car, it will last about a tank depending on how much boost you are using.
Old May 9, 2005 | 08:37 PM
  #109
Ted B's Avatar
Two observations:
(1) What are you injecting?
(2) That can't be anywhere even close to correct because it equals 3000cc/min.
Old May 9, 2005 | 08:44 PM
  #110
jj_008's Avatar
(1) I was injecting windshield washer fluid. It didn't really gain anything for me so I haven't been using my WI system.
(2) I am using the biggest nozzle available from aquamist. As for draining the bottle, it was roughly 20 seconds. Just went and looked at my bottle it holds 20oz not a liter.
Old May 9, 2005 | 08:47 PM
  #111
Mistasparkle's Avatar
Hey ted,
im getting the same 280s, 780cc injectors, fuel rail, head studs, springs and retainers installed.
you told me that uploading the standard stage 1+ map would be unwise.
what do you think i should do to dial this thing in? I cant really make the 6 hour trip up to vishnu since im in so cal (pasadena)
Old May 9, 2005 | 08:52 PM
  #112
Ted B's Avatar
Still, I'm very surprised you didn't lock the engine, and you're very lucky you didn't. I can't believe it even ran.
60oz/min = ~1800cc/min, which is waaaaaaay out of bounds for a 2.0L engine.
Water injection (or a mix with water) for this engine would be in the 200-300cc/min range.
Injecting meth at 1000cc/min is significant, and requires qually significant dyno tuning to compensate. If I just sprayed the meth in the engine with no tuning, it would be pig rich and run like crap.
Old May 9, 2005 | 08:57 PM
  #113
Ted B's Avatar
Originally Posted by Mistasparkle
Hey ted,
Well, for starters, the 780cc injectors alone will cause it to run like *** without having a rescaling reflash of your ECU. Better send your ECU to Vishnu for a reflash when you install them.
Furthermore, 780cc injectors aren't of any benefit unless you're going to be installing a GT35R along with that (or at least a 3037). Ditto for the fuel rail. Are you planning on installing a BIG turbo?
Ask Shiv for a map for a car with the 280s and a similar setup. It won't be exact, but it will be a better temporary option than using a map for something different.
Old May 9, 2005 | 09:00 PM
  #114
jj_008's Avatar
I will have to check my notes at work. I had it all setup on a desk and was running some tests. I keep thinking it was 20 seconds in order to drain that 20 oz bottle.
I had the car custom tuned by Shiv, but he didn't make any more power w/ the WI running. If I would of had methonal, then it would of been a whole different story.
Old May 9, 2005 | 09:24 PM
  #115
jj_008's Avatar
Ok, I found an email I sent out to my brother w/ my results. The pump did drain 20oz in 20 seconds, but that was w/ out the nozzle (duh ). The flow rate I calculated, with the 1mm nozzle, was ~0.350l/min or 350cc/min. With the nozzle, it drained my 1 liter bottle in about 160 sec.
That should clear things up.
Old Jun 10, 2005 | 12:43 PM
  #116
superman105's Avatar
Ted B
where did you mount the tank in your trunk ?
can you post up a picture
tks
Old Jun 10, 2005 | 12:50 PM
  #117
Ted B's Avatar
My alcohol reservoir is my IC sprayer reservoir.
Old Jun 10, 2005 | 12:53 PM
  #118
RallyRedEVO's Avatar
Did you move it to the one in the rear? Or are you still using the front one?
Old Jun 10, 2005 | 01:04 PM
  #119
ArchieBabes's Avatar
I have mine set to spray at 1psi of boost and max spray at 14psi
Works like a charm
Old Jun 10, 2005 | 01:12 PM
  #120
Ted B's Avatar
I'm using the front one. I have a plastic bottled drilled for the IC sprayer parts and I will install that with a mini-battery to keep the IC sprayer functional.
I don't like switches that do nothing.
