Dyno Results - HKS 280 + Methanol
Old Apr 4, 2005 | 10:41 PM
  #76
Drews_WRX's Avatar
Originally Posted by IE Evo
LOL Me and JP are in trouble!BTW I think that guy in the deisel truck thought we were in Subies as that is why he thought he could own us. LOL
ROTFLMAO. funniest thing you have EVAR said. I bet he had some "you just got stallowned by a TURBO" stickers ready to slap on the cars after he took us down
Old Apr 4, 2005 | 11:23 PM
  #77
IE Evo's Avatar
Wierd dude and a lot of wierd stuff going on in the area. That guy was hilarious and he was calling us Fast and Furious wanna be jap crap etc. I guess JP can be Paul Walker and I am a fat old unhot Vin Diesal and U are the guy in the white jetta with ADHD that gets owned for pink slips by the s2000.LOL
Old Apr 6, 2005 | 03:15 PM
  #78
JP98SS's Avatar
He did chirp the tires...around the corner. lol
Old Apr 10, 2005 | 03:35 PM
  #79
EVO8LTW's Avatar
Given the blue flames that the car shoots out the tailpipe on meth, would it be a bad idea to run a cat with meth injection?
Old Apr 10, 2005 | 07:37 PM
  #80
Ted B's Avatar
Actually the presence of a cat mitigates the flame because the basic purpose of the cat is to light off any unburned fuel. The cat will work at least as efficiently for methanol as it would for gasoline, and would eliminate the flame.
Old Apr 10, 2005 | 09:30 PM
  #81
Ted B's Avatar
Hmmm, looks like I better start saving for a new clutch. At the local grudge matches on a private stretch tonight (no laws being broken), the ONLY thing able to stay out of my rearview mirror was a worked over GT on street slicks with a big nitrous shot (runs 11.80s). Everything else was toast and got a view the blue flames from my tailpipe. Needless to say, I'm satisfied.
...but I began smelling my own private 'clutch BBQ' in the process.
Old Apr 10, 2005 | 11:05 PM
  #82
value's Avatar
Ted very amazing story . It has opened my eyes to meth inj. How long do you guess a tank would last during spirited street driving no track time ??
Old Apr 11, 2005 | 06:04 AM
  #83
Ted B's Avatar
The methanol does not last very long, considering the injection rate is right around 1000cc/min. Nevertheless, it lasted long enough for me to easily smoke the top challengers. The car is so quick, that I was usually able to shut it down early in 3rd and call it a win. No one argued!
Now, as to how long the fuel tank lasts, the answer to that is rather surprising. See this:
https://www.evolutionm.net/forums/sh...54#post1849454
Old May 2, 2005 | 04:15 PM
  #84
superman105's Avatar
can you explain to me why you decide for the menthol to come on at 15PSI and max by 20PSI of boost ?
Old May 2, 2005 | 04:18 PM
  #85
Ted B's Avatar
Menthol is what I spray in my interior to keep it minty fresh.
On the other hand, the methanol doesn't get engaged until ~11psi because it's not needed earlier. It reaches peak flow at 20psi and holds it to the top (25psi) because this is where peak methanol flow is required to get the most hp.
Old May 2, 2005 | 04:21 PM
  #86
Ted B tks for your reply
my bad yes I like menthol too :-D
how did you figure out how many methanol to inject to make a 91 octane comparable to 100 octane
Old May 2, 2005 | 04:31 PM
  #87
Ted B's Avatar
The idea is to inject enough methanol such that it displaces some gasoline, then retune the A/F to get what you had before. If you can inject enough methanol and tune accordingly, you'll eventually get that 91 oct to perform like 100 oct or so.
Old May 6, 2005 | 01:11 PM
  #88
flipguy88's Avatar
So who would I need to contact if I wanted to a buy the alcohol injection kit but do like you did and still have a functional water sprayer for my IC?
Old May 6, 2005 | 01:15 PM
  #89
Ted B's Avatar
You would contact Steve at SMC (http://www.smcenterprises.com/alcohol.htm) and tell him that along with the kit, you want a bottle that is drilled for the IC sprayer parts.
The trouble is where to mount the bottle. In my application, about the only option I have is to run a smaller battery to make space.
Old May 6, 2005 | 01:17 PM
  #90
Ludikraut's Avatar
IMHO, I'd just re-route the rear window sprayer to feed your IC sprayer. Run the piping, and re-wire the denso pump to the IC switch and you're done, which would free up the front reservoir for other uses
l8r)
