Dyno Results - HKS 280 + Methanol
Old Apr 4, 2005 | 01:46 PM
  #61
boostfed's Avatar
Ted: It was great to meet you. I really enjoyed watching your car get tuned (I'm gonna make sure I bring some hot dogs next time)).... also.. thanks again for the cams. I'm really gonna enjoy the 272's in my car. good luck with your car. It was really impressive and I hope everything works out great for you...
-Chad-
Old Apr 4, 2005 | 01:48 PM
  #62
robertrinaustin's Avatar
From: Work - New York, Alaska, Mexico or the Caribbean. -Home - Tx Hill Country
So what are new cams set at?
Old Apr 4, 2005 | 01:51 PM
  #63
Ted B's Avatar
Originally Posted by WOT
What are you going to do with the 272's? Are they sold yet?
Yes, I sold them to boostfed above, as you can see from his post.
Old Apr 4, 2005 | 02:15 PM
  #64
Drews_WRX's Avatar
Great Numbers.
I am impressed with the gains of the 280's over the 272's between 3,800 - 5,600
Granted ther are other reason's for the power boost besides the cams, but you added an awesome increase where 99% of evo owners visit with regards to revs!
I geeked together an overlay between the 2 cams on 93 octane, hopefully it's viewable.
I would go that far.........yet. Clearly the guy did NOT just swap the 280s in favor of the 272s. He added a test pipe, IC pipe, Nisei intercooler, etc. To 272 owners, I would just go out and swap for the 280s becuase of these charts.
IMO-the only real "right" way to compare 2 different sets of cams, is to only swap out the cams, and have them at the same cam timing marks....
Old Apr 4, 2005 | 02:23 PM
  #65
Ted B's Avatar
My activities were not intended to represent an A/B cam comparison, and they should not be construed as such. I am simply preparing this platform for a large turbo.
However, he who thinks that a larger IC, upper IC pipe, and crank pulley will make significant gains in power at this level is living in a dream.
Old Apr 4, 2005 | 02:40 PM
  #66
Drews_WRX's Avatar
i know your intentions werent to make this an a/b cam comparo. Is it not true that a test pipe will make 10-15whp? an bigger, more efficient intercooler core w/tuning make 5-7whp? Come on.....dont all of these start to add up at some point?
Furthermore, I am not suggesting that the 280s DONT make more power, as I am sure they do...just not ~20whp than the 272s.
Nice results and good luck w/the bigger turbo.
Old Apr 4, 2005 | 02:50 PM
  #67
Ludikraut's Avatar
Actually if you set them to hit their power peak at a higher rpm, then 20whp is not unreasonable. Buschur certainly got that on his RS with the cams set to 0,0. Ted, however, didn't get more peak HP, he went for more torque, which he's got in abundance. But, yeah, on Ted's car it's definitely not an a/a comparison
l8r)
Old Apr 4, 2005 | 02:55 PM
  #68
Ted B's Avatar
FWIW, the test pipe is the most significant 'performance' item that we added. FWIW however, others with the same effective setup and tuning, with large IC, test pipe, and 272s are making on race what I'm seeing on 93 oct. As Ludikraut illustrated, consider the fact that they are running -3/-3 and I'm using +2/0, which only widens the gap.
This being said, while I wouldn't guarantee an additional 20whp with proper tuning, neither would I say that it is unreasonable simply because it's been demonstrated elsewhere.
Old Apr 4, 2005 | 03:54 PM
  #69
IE Evo's Avatar
Drew just because WRX's make no power with mods does not correlate to the Evo. I believe those Cams might be good for 20 + whp between 6000-7800 rpms and with Teds settings = more low end tq. It appears that from other tuners that these cams are proving to make good power and 20 peak whp seems to be pessimistic. But even if it is only 10 peaks whp the 30-40 whp gain in the upper rpms is more than worth it.
Old Apr 4, 2005 | 04:28 PM
  #70
Drews_WRX's Avatar
yeah right....whatever..... just wait til I install my 272 cams in the WRX
Old Apr 4, 2005 | 04:38 PM
  #71
IE Evo's Avatar
LOL Me and JP are in trouble!BTW I think that guy in the deisel truck thought we were in Subies as that is why he thought he could own us. LOL
Old Apr 4, 2005 | 04:54 PM
  #72
cHuCkUfArLiE's Avatar
Originally Posted by Ted B
I'll take the PHATT midrange and the confusion it will cause to many a V8 lover.
This is very true. 280s are the Chit! right now.
Old Apr 4, 2005 | 06:42 PM
  #73
gsujeff55's Avatar
phatt midrance you will get from 272s at that setting won't you?
Old Apr 4, 2005 | 08:23 PM
  #74
RallyRedEVO's Avatar
Shiv makes all that power with Ted's car, and look how he thanks Dyno4mance....
By trying to burn the place down!
Old Apr 4, 2005 | 08:25 PM
  #75
matt55's Avatar
oooh , that's hot
