Isn't That Lean?
Old Aug 14, 2006 | 12:51 PM
  #316
Spec'd's Avatar
I added comment to my post above. ^^
A good dyno session sounds like a good idea.
I was going to have the Xede tuned on a dyno with Shiv.
I'm starting to realize that the Xede seems limited.
What's the point of having two switchable MAPS
if there isn't much difference in boost levels between both MAPS.
( I don't want to have to always remove the Xede boost emulator
every time I switch MAPS ).
I would love to try a GM Map sensor with ECU+ or MAF Pro.
I might do it anyways for a while.
Also electronic boost control would seem like an exiting idea.
Old Aug 14, 2006 | 01:40 PM
  #317
jrsimon27's Avatar
wow 11.2 on race gas thats conservative cause my off the shelf map from the vishnu site in 3er gear pulls i saw afrs fluctuate between 12.0-12.5 know i have them at 11.0-11.3 i added fuel!
Old Aug 14, 2006 | 02:04 PM
  #318
RazorLab's Avatar
It's my beat on it all day long on the track tune. It is very conservative.
Old Aug 14, 2006 | 09:50 PM
  #319
Spec'd's Avatar
Conservative is good.
Old Aug 14, 2006 | 09:59 PM
  #320
Erik@MIL.SPEC's Avatar
I'm assuming you're talking about the fact that your boost tables are almost maxed out on 91 octane? If so, there is a fix for this. Just call the folks at vishnu and say you want to run more boost on 100.
Old Aug 14, 2006 | 10:44 PM
  #321
Spec'd's Avatar
I meant that I want 23 pounds or so on one MAP while having 21
pounds on the other.
If I install the boost emulater to make the boost higher on a 100 Map,
can I tune the boost table lower on the 91 MAP ?
Old Aug 14, 2006 | 11:27 PM
  #322
nj1266's Avatar
Can't you just remove a certain % from the boost table until you hit 21 psi? On the other map increase the boost a certain % until you hit 23 psi.
On my custom 91 octane map I was hitting 22 psi and on the custom 100 octane map I was hitting 24 psi. On some cool nights I even hit the fuel/boost cut.
Old Aug 14, 2006 | 11:28 PM
  #323
nj1266's Avatar
So you have added more fuel to your maps? For a while you were running 11.7ish, IIRC.
Old Aug 15, 2006 | 12:26 AM
  #324
Spec'd's Avatar
Yes I think I can do that.
Ok now the default 91 Xede boost table gives me 21 sometimes 22.
The default 100 Xede boost table gives me 23 sometimes 24.
I can now hit fuel/boost cut.
Old Aug 15, 2006 | 02:37 AM
  #325
Vishnu_Evo8's Avatar
My 91 map is set to 21-22 psi, and my race one is set to 28 psi.
Old Aug 15, 2006 | 03:14 AM
  #326
Spec'd's Avatar
How did you get 28 on your race map ?
Old Aug 15, 2006 | 06:42 AM
  #327
nj1266's Avatar
What do you mean by "default?" Do you mean the way it was set by Shiv?
Old Aug 15, 2006 | 06:44 AM
  #328
nj1266's Avatar
He probably has the ECU flashed to remove the boost limit.
Old Aug 15, 2006 | 12:05 PM
  #329
Jeff_Jeske's Avatar
The difference in performance between a race gas map and a pump gas map come from the following:
1. The recovery of 3-4* of timing from 6k-8k. (primary RPM range during drag race)
2. Maxing boost table to 100% increases low rpm boost spike which sometimes helps decrease high end boost drop.
3. Leaner AFR. Pump=11.5:1 Race=12.5:1
4. If you had knock race gas normally eliminates it unless you are running your turbo to hot or do not have enough intercooling.
On race gas I pick up nearly 40WHP.
Old Aug 15, 2006 | 12:40 PM
  #330
jrsimon27's Avatar
yep with the base maps 3erd gear pulls afrs fluctuated 12.0-12.5 know i have it all the way to 11.0-11.3 this is a 3erd gear pull also.
