Isn't That Lean?
Old Aug 15, 2006 | 02:11 PM
  #331
Spec'd's Avatar
Originally Posted by nj1266
He probably has the ECU flashed to remove the boost limit.
I have ALL the tools I need now to do that.
Old Aug 15, 2006 | 05:16 PM
  #332
nj1266's Avatar
Here is something that some might find interesting. I did two logs today. One on a flat on ramp and the other on a decline on ramp. The afr logged on the decline ramp was a bit leaner than the one done on the flat surface. From now on I will try to do all of my logs on a flat on ramp. These are not easy to find, but they are around. Here are the tables:
Flat on ramp
Decline on ramp
Attached Thumbnails Isn't That Lean?-afr_decline_surface.jpg   Isn't That Lean?-afr_flat_surface.jpg
Old Aug 15, 2006 | 05:19 PM
  #333
nj1266's Avatar
I too have the tactrix cable, but I will keep the boost cut in the ECU. I like the protection that the ECU provides.
Old Aug 15, 2006 | 05:23 PM
  #334
nj1266's Avatar
Originally Posted by Jeff_Jeske
The difference in performance between a race gas map and a pump gas map come from the following:
1. The recovery of 3-4* of timing from 6k-8k. (primary RPM range during drag race)
2. Maxing boost table to 100% increases low rpm boost spike which sometimes helps decrease high end boost drop.
3. Leaner AFR. Pump=11.5:1 Race=12.5:1
4. If you had knock race gas normally eliminates it unless you are running your turbo to hot or do not have enough intercooling.
On race gas I pick up nearly 40WHP.
Keep in mind that this approach is good for drag racing. But it is not as good for road course driving. On the road course, I do not advise people to run more than 11.5:1 afr even with 100 octane gas. Also keep the boost no more than 22-23 psi. This is for the conservative road course driver who wants to drive his car home in one piece from the track.
Old Aug 15, 2006 | 05:37 PM
  #335
RazorLab's Avatar
Makes sense since an incline will put more load on the motor making it move into load column to the right with lower timing and richer AFR. Decline will be less load, moving load column to the left, which has higher timing and leaner AFR.
Well, unless you have all 8's and 7's in your maps...
Old Aug 15, 2006 | 07:03 PM
  #336
Spec'd's Avatar
That makes total sense. That's more or less the problem I was having a few
days ago. That's why I thought an abandoned airstrip or dyno would
make it easier to get more consistent readings.
Old Aug 16, 2006 | 05:33 AM
  #337
Jeff_Jeske's Avatar
These days I can't afford to run race gas for road racing. Now I keep my pump gas maps loaded and then dump 3 gallons of 110 in the tank for safe measure.
In the past I safely run 100 octane @ 22PSI with a 12:1AFR and the tune was nearly knockproof for me. In fact I can't remember a time that I've seen knock on straight 100 octane. Its just too damn expensive.
I think most people just fatten their tunes for road racing events.
Old Aug 16, 2006 | 07:57 AM
  #338
nj1266's Avatar
How were you tracking knock, Jeff?
Old Aug 16, 2006 | 08:40 AM
  #339
Jeff_Jeske's Avatar
Well I've traced knock a few different ways. First I was using a 95 GSX ecu with DSMLink. This directly interfaces with the knock sensor.
Then I switched to the Xede with knock buffer.
I have also used pocket logger software on a laptop to log ignition timing retard.
I've logged while on the dyno and can tell you that reading ignition timing was more accurate than the knock buffer. Dips in power on a pull matched perfectly with the retard of timing. You just have to keep in mind there are other reasons outside of knock for timing changes.
Old Aug 16, 2006 | 09:14 AM
  #340
nj1266's Avatar
Logging knock has been the hardest thing to do so far. I too have used the pocketlogger to track ignition timing retard.
I have a knock buffer installed and tracked knock with it. In certain loggs there seems to be overlap between timing pull and a spike in the knock buffer voltage. In other logs there is no overlap.
Yesterday I got te Tactrix cable and I am using Evoscan to log knock sum. The one log that I did had a max of 5 knock sum in it. I was told that anything less than 7 is ok.
My problem with the Knock Sum system is that it is getting its info from the OBD2 port. We now know that the reading timing from the obd2 port when you have an Xede is NOT the real timing. Could it be that reading the Knock Sum from the obd2 port is also NOT the real Knock Sum?
What do you think Jeff?
Old Aug 16, 2006 | 10:09 AM
  #341
Jeff_Jeske's Avatar
Timing is being altered by the xede.....knock isn't. Knock is knock.
Even though the xede retards timing you shouldn't see it at the OBD2 port. If you do see retard then you know some variable caused it. (variable= intake temp, air flow, coolant temp, knock, ect)
Old Aug 17, 2006 | 11:15 PM
  #342
nj1266's Avatar
I have been logging my timing and knock with Evoscan for the past few days and I have to admit that it is a much better program than the often used pocketlogger. The logging speed of Evoscan is much better for timing than the pocketlogger.
I have also had a chance to compare the Knock Sum (KS) reading of Evoscan to the Knock Buffer (KB) reading of chiptorque. It is simply amazing how both of them detect knock at the same time. Whenever there is a significant spike in the KB there is an increase in the KS reading.
Apparently, I have been getting a single knock event in the higher RPMs. I confirmed it with both KS and KB. Here is the chart of the log so you can see. Notice the spike in the KS and the KB at the same rpm point. Inorder to draw the KB on the chart (which is in 0-5 volts and usually fluctuates between 0.6-2.3 v), I simply multiplied the results by a factor of 10. So the 16.6 black spike is actually a 1.66 volt spike. Notice also how the timing got pulled by 3 degrees when the spike and KS increased.
Rather than richen the map, I followed the Klaus Almendinger school of tuning and backed off the timing. I simply used the 91 octane timing map that Shiv uses in the 91 octane off-the-shelf map.
That seems to have done the trick since the next two logs at the same place and similar time produced no spike/KS in the log.
Attached Thumbnails Isn't That Lean?-93_timing_knock.gif   Isn't That Lean?-91_timing_no_knock.gif
Old Aug 18, 2006 | 03:42 AM
  #343
Spec'd's Avatar
I like those Excel graphs.
Can one assume that your fuel mixture is approximately 93 octane ?
Are you using only the " timing " part of the 91 off the shelf map ?
How much more advanced was the timing portion of your own custom map ?
Did you completely follow Klaus Almendinger's school of tuning with
higher a/f ratios or just timing retard ? ( that's kind of a redundant question )
Old Aug 18, 2006 | 06:58 AM
  #344
nj1266's Avatar
I like Excel a lot. I think it is a very versatile program. I use it for my work and for my hobby.
Yes. Since I have gone to 93 octane I have not been back to the 91 pisstane.
Yes, I am only using the timing part. I have also reduced the boost to about 22 psi spike even when it is cool in the evening hours.
I was using the 93 octane timing map withing the off-the-shelf Shiv 93 map. I think the 91 and 93 octane maps are the same up to about 5000 rpm, then the the 91 timing is pulled slightly more than the 93 timing.
So far I have kept my AFR steady at 11.5:1 and slightly backed off the timing and the boost. I finally got my EGT gauge in the mail I hope I can find time this weekend to install it. I hope that my EGTs are below 850* C. That will give me more confidence in this tune.
The real test would be on the dyno. I need to book some dyno time with Alfred @ Tuning Tech and see where the car is power wise.
Old Aug 18, 2006 | 07:35 AM
  #345
TTP Engineering's Avatar
Tried to tell you...
Also your EGT's will be 930-950*C, not 850. We'll see. Hopefully you will have purchased a fast reacting accurate probe such as a kflex thermocouple.
