Buschur/Dynoflash/SMC alky kit problem?
Old Nov 28, 2005 | 06:47 PM
  #91
BJai02's Avatar
I am not here to argue, but to find as much information as I can. I rathe ruse my own judgement to filter any information that I am not agreed upon . So here goes:
My friend raised a question of using 100% methanol along with a VTA BOV.
At 20+ psi, there is no chance for teh methanol running downstream. But when the alky injection running at full blast at WOT, with a sudden close of the throttle, the alky and air are both shut off from entering the throttle body. The remaining air will be blew off from the VTA BOV... along with some methanol Does it spell ENGINE FIRE??
What are your thoughts on this, Mr. Buschur? Al? Shiv?
Old Nov 28, 2005 | 06:49 PM
  #92
DynoFlash's Avatar
Witha VTA BOV it is imperative that the injection jet be placed cloaer to the TB and the VTA BOV be placed down by the air intake area
What ever you do don't place the jet before the bov !
Old Nov 28, 2005 | 06:52 PM
  #93
mike 99gsx's Avatar
This seems like a legit concern in theory but doesn't seem to be an issue in real world scenario. For example, look at methanol only setups where methanol injectors are being used right after the compressor outlet (John Shepherd). However, I probably wouldn't be doing it in a street car though
Old Nov 28, 2005 | 06:58 PM
  #94
shiv@vishnu's Avatar
This is a very legitimate concern, imho.
-shiv
Old Nov 28, 2005 | 06:59 PM
  #95
cfdfireman1's Avatar
Originally Posted by Richard L
Which is more effective? Both, all depend on your approach - my personal view. Water although do not have any octane rating but it has a positive effective octane influence on any fuel, not so easy to quantify. Methanol does have a direct influence on octane rating and can be calculated. To further compare the two beyond mentioned is almost impossible. As regarding tuning potential, they are quite similar, the result will be resting on the person's preference and ability, it is a very personal affair. In the days where competing businesses meet in a public forum, exhibiting a good impression to potential custom is important. Because if this pre-condition, sometimes leads to unnecessary heated discussion that leads to nowhere and the meaning of a discussion is lost - giving example and dyno chart is meaningless - once you grasp the basics of the two concepts, you cannot go wrong. History has always shown the injected ratio as 50/50 - no winner or losers there...
Richard
Is this the same Richard L. that posted the answer to this question back in August?
""Richard: Can you achieve the capability of pure MeOH injection with just water alone?""
No contest, water cannot compete with alcohol when the purpose is for supplimenting the pump fuel's octane rating. It is like comparing injecting gasoline against injecting methanol or injecting methanol and nitromethane.
https://www.evolutionm.net/forums/sh...24&postcount=3
Old Nov 28, 2005 | 07:01 PM
  #96
With air traveling at such a high velocity, that 12" of distance is insignficant. Methanol (hopefully in gaseous form) will dump out of BOV.
shiv
Old Nov 28, 2005 | 07:09 PM
  #97
DragNRacing's Avatar
What about tapping into the manifold? That would overcome the risk but are there any issues with it not being distributed evenly or otherwise?
Old Nov 28, 2005 | 07:50 PM
  #98
DynoFlash's Avatar
Interesting
Old Nov 28, 2005 | 07:51 PM
  #99
SlowCar's Avatar
Check out the water injection forum, lots of information. There are cars on there w/ Direct Port water injection, similar to DP nitrous...
http://www.waterinjection.info/phpBB2/
Old Nov 28, 2005 | 07:54 PM
  #100
DynoFlash's Avatar
shiv
Shiv - in my 9.984 race evo (details - Turbo Magazine Jan 2006 issue) - I run the same exact alcohol kit I sell to my customers
I run in excess of 45 psi of boost and a very active TiAl VTA BOV
The exact distance between the BOV and the alcohol jet is 19"
I have never seen ANY plume of methanol release from the bov to date what so ever
I have never had any isssue what so ever
Of course - with all evos I would always recomend a re-circ BOV with the stock ecu and maf sesnsor - especially when using alcohol
However - I personally have not seen any problems and my car has been to 9 races this year and countless hours on the dyno where air flow is minimal
Old Nov 28, 2005 | 07:57 PM
  #101
DynoFlash's Avatar
Very soon when i find more time I am going to add a set up like this one in my car
Old Nov 28, 2005 | 08:03 PM
  #102
SlowCar's Avatar
Dont forget to mention you are using
1- Very high octane fuel
2- Big efficient TURBO
and again, please compare apples to apples. Most guys here running injection kit have their stock turbos. Anyone running your same setup will get the same result...maybe better. Timing/Fuel/Boost, thats all there is!
Old Nov 28, 2005 | 08:14 PM
  #103
DynoFlash's Avatar
The fuel I am using and which turbo is IRRELEVANT to the issue of the question will methanol go backwards 19" and go out the BOV - I certainly am injecting about 3 times the amount of methanol as any of my customers and would be more likely to have such a problem
BTW - I guess the same theory would apply to fogger NOS systems which squirt fuel and NOS into the upper fmic near the TB - mine does not shoot out the bov either - no problems that I have heard
Old Nov 28, 2005 | 08:21 PM
  #104
SlowCar's Avatar
Chill big guy, what i was refering to was "Shiv - in my 9.984 race evo (details - Turbo Magazine Jan 2006 issue) - I run the same exact alcohol kit I sell to my customers "
apples to apples, oranges to oranges, stock turbo to stock turbo.....name me the ppl on here that has a turbo as humangous(sp?) as yours AND running the same alky kit as you? You prolly will run 9.983 w/o the alky kit.
Old Nov 28, 2005 | 08:38 PM
  #105
SlowCar's Avatar
Al, you will be tuning a car Dec04 on vividracings MD with 100% R-OH. Do your best in that tune and see what numbers you can get. I'll reconfigure my 100% water injection system and have Nick from PD tune it when he comes back, and see what i can get.
I really want to see where the limits of water is and if it is able to stand up to the challenge of pure R-OH. Deal?
I wish i'm a better driver at the track so that 1/4mi times can also be included...but my track skills sucks.
