View Poll Results: is it ok to use meth/water injection during winter
yes
100.00%
no
0%
Voters: 12. You may not vote on this poll
winter use
Old Nov 11, 2008 | 09:30 PM
lemmonhead's Avatar
winter use
how many of you dont use it during winter?
Old Nov 11, 2008 | 09:33 PM
sikrsix's Avatar
This shouldn't be a poll, but an answer to a question that is probably overlooked for us "snowbirds." I would assume it would freeze being mixed with water?
Old Nov 13, 2008 | 10:26 AM
lemmonhead's Avatar
come on its free im not charging a dime for this poll. so go out and vote its your responsibility as an american
Old Nov 13, 2008 | 10:49 AM
Vivid Racing's Avatar
In az I do still see the need for it removing it. I usually keep the same mix at 50/50 to keep the water from freezing. I just do a slight retune add more timing less fuel ect ect.
In other parts where its colder I can understand to reduce the jetting size.
Evan Smith
Old Nov 13, 2008 | 11:19 AM
dudical26's Avatar
I have run it in freezing winter temps of -10*f
At that time I was running 100% meth though.
You can calculate the freezing point of any meth/water mixture. Just make sure that whatever mixture you use has a freezing point below any temps that you will see.
Old Nov 14, 2008 | 09:39 AM
lemmonhead's Avatar
I dont think the freezing is the issue why you would turn it off in the winter. I think the issue affecting of the atomization and condensing so there is uneven distrubution. Since your temps will not be as high less heat transfere to take place so less of phase change from liguid to vapor of the methonal.
any thoughts on that?
Old Nov 27, 2008 | 08:00 AM
drop24's Avatar
Bump. Want to know if meth is safe in the colder climates.
Old Nov 28, 2008 | 08:54 PM
dudical26's Avatar
read my post, about 2 posts up. I have used it in sub zero temps.
Old Nov 29, 2008 | 07:39 PM
drop24's Avatar
lemmonhead has a good point about condensation though.
The_X_Effect
For Sale - Wheels / Tires
Jan 19, 2017 12:57 PM
wntanEVO
Pacific Northwest
39
Jan 20, 2013 11:35 PM
cnj4ever
13
Sep 4, 2009 06:24 PM
Chuckdimpala
May 8, 2009 08:06 AM
Xs2000
17
Nov 1, 2004 05:04 AM
