The California Smog Law(s) Thread [MERGED]
Old Jul 22, 2013, 01:51 PM
  #361
Boosted Tuning's Avatar
Glad to hear you got it to pass.
Old Jul 22, 2013, 02:01 PM
  #362
SLVRNBLK's Avatar
I need to research some more and see if there any that pass CA smog.
I run GSC S1 and passed with no problems. I run an FP Black, E85 set-up and it's more than enough power for me on the streets. I only have to make a few modifications (exhaust and intake) when I have to smog the car. The cams are holding me back on power, but it's worth it for smog purposes.
Old Jul 22, 2013, 02:37 PM
  #363
EvoM Community Team
golgo13's Avatar
Originally Posted by Racerx9146
I suppose some combo of tune/cam timing might pass with the 272's.
This is how I would do it, in addition to running the OEM catalytic converter. Swapping the cat in and out only takes an hour at most.
You can run a daily driving map and a smog/base/valet map for this very purpose with EcuFLASH.
Install your CAT and then switch to the milder map when you're ready to bring the car in and back to your aggressive map after you get your CAT back in.
Old Jul 22, 2013, 06:13 PM
  #364
Racerx9146's Avatar
Thanks for the feedback. Jay looking into getting some milder cams, throw the Perrins full exhaust back on and I will be up to see you for the tune.
D
Old Jul 22, 2013, 06:59 PM
  #365
He said that he did install his stock cat.
He had Kelford 272s which usually dont pass. Something milder like an S1 will usually pass. Also, some tuning might make it pass with the Kelfords, but I didnt tune his car, so who knows.
Old Jul 22, 2013, 07:21 PM
  #366
EvoM Community Team
golgo13's Avatar
Only missing variable was the tune.
Old Jul 28, 2013, 04:40 PM
  #367
evoiao's Avatar
i passed w 272s, skunks intake and 68mm tb, hks cat back, ported mani, aftermarket o2, and dwn pipe, on e85.
Old Jul 28, 2013, 05:24 PM
  #368
gotpsi?'s Avatar
You can pass on 272s no problem just smog it on e85.
Old Jul 29, 2013, 09:09 PM
  #369
bullet206's Avatar
to be honest its just defends on whos inspecting your car.. i just recently pass smog in daly city with hks 272 ets gt30r etsexh manifold with 42 mm xternal wastegate with no prob it just took him a while cus i kept lookin at my turbo just sayin..
Old Jul 29, 2013, 10:43 PM
  #370
thatguy5's Avatar
anyone know when ab2289 is supposed to be in full effect? I just received my registration today and I have to go in for smog
Old Jul 30, 2013, 11:26 AM
  #371
Racerx9146's Avatar
The smog tech I just talked to said later this year but don't hold your breath, it's been postponed a few times....
Old Jul 31, 2013, 10:57 AM
  #372
evoiao's Avatar
This worked for me and my set-up.
Old Jul 31, 2013, 09:17 PM
  #373
Racerx9146's Avatar
272's
So I had my mind made up to trade my Kelford 272's for a milder cam that might pass smog but with all the feedback from people passing on 272's but running e85 I am reconsidering.
So in order to do this I would need too.(?)
Install e85 compliant injectors
Tune/modify my car to run dual maps
The one thing that keeps bothering me is how much nice the car is to drive with the stock cams. I have driven the car for a week with the stock cams and it lost the massive top end but gained some low end power. it ps much nicer for daily driving, Especially with the A/C on. Is is possible to tune the car to dial out some of the bad idle issues with the 272's or does that just come with the territory?
Daron
Old Aug 1, 2013, 06:51 AM
  #374
gotpsi?'s Avatar
If you are just looking to smog and don't want all the benefits of e85 just change your setting for your injectors in ecu flash by 30 and double the cranking pulses, that should at least make it start and run, the drive it down and smog it. No boost! And you should be fine. Then go home and flash it back, drain the e85 and put gas back in. Our cars have these awesome plugs on the bottom of the tank that make draining easy. If you want to stay running in it contact whoever you want to tune the car and have them recommend larger injectors for you and a pump that will meet your goals and have them do a full tune with the new parts. But to smog you will be fine with what you have, but like I said, stay out of boost.
Old Aug 2, 2013, 08:43 PM
  #375
bullet206's Avatar
i had hks 272 on mine on pump and pass with no prob i just had to scale my injectors n put my stock exhaust so loop on my cams wont be too noticeable
Quick Reply: The California Smog Law(s) Thread [MERGED]
