Utah Evos
Old May 2, 2009 | 05:59 PM
  #24331
wesside's Avatar
Originally Posted by sikwititevo9
thats good. i wish i could keep up with you guys
You've got that big turbo your going to be throwing on I'm sure you'll end up with a lot more power then me you'll prob be over 400 on pump? 500whp I'm sure with meth or e85
After I get rotors & pads I'll get a bigger fmic and pull another 20whp or so
****ing Evom being slow as **** again FTL
Old May 2, 2009 | 06:00 PM
  #24332
gear head's Avatar
Originally Posted by DIDYSIS
anyone on here run an EGR block off plate??
I blocked mine off inside the head
  #24333
wesside's Avatar
Id hook you up
SWEET
Old May 2, 2009 | 06:02 PM
  #24334
wesside's Avatar
9 with meth cams and about 27psi or more will make 400+ WHP, or just do 30PSI and its all good also. Been there done that. its a blast to go from 30-130mph
What power range you think your at? I think my friend with 100oct 27psi on his evo viii 2.3l w/35R was early 500's on the mustang dyno
  #24335
gear head's Avatar
Originally Posted by wesside
if you do then you should hook me up with your egr valve I get the p0401 egr valve insuffecient valve flow and I disabled the code...I think it's prob just dirty or **** for all I know it's stuck open / closed ?? I should pop it off one day but if you ditch yours then I could throw it on and re enabled the code to see if it gets thrown again
turn that off in the Periphery bits
Old May 2, 2009 | 06:05 PM
  #24336
wesside's Avatar
That's better right? Isn't having the block off plate somewhat like having a vacuum / boost leak well not really leak...I forgot how it was explained
  #24337
sikwititevo9's Avatar
List mods again please and Ill give my guess.
everything i have on my signature plus the garrett turbo, 880cc injectors, 38mm wastegate, aluminum intake manifold, tubular manifold
Old May 2, 2009 | 06:06 PM
  #24338
gear head's Avatar
Yes, then there is NO hot air inside the intake
Old May 2, 2009 | 06:08 PM
  #24339
wesside's Avatar
Yea I've had it turned off since I got to ecuflash 1.41
I got the p0505 kicked a few times yesterday...?? cold weather ? Sometime when your free if you could help me fix that real quick, I hate not having my own garage right now I should check boost on my non meth map too and see what psi I'm at and get that a lil adjusted too
Old May 2, 2009 | 06:09 PM
  #24340
wesside's Avatar
aaah so how difficult is this to do? Any negative side effects? Pass emissions still or do we use our lil emissions trick to get past that
Old May 2, 2009 | 06:11 PM
  #24341
gear head's Avatar
Yeah, it"s just a minor adj. of the BISS. I'll probably be looking for something to do next Sat. afternoon.
I remember the days without a garage...that sucked *****
Old May 2, 2009 | 06:13 PM
  #24342
gear head's Avatar
You need to pull the intake off & thread the EGR port in the head for an NPT plug.
Then you can turn off all the EGR stuff & use the OBD Monitor Patch to set everything as ready
Old May 2, 2009 | 06:14 PM
  #24343
DIDYSIS's Avatar
I want to be at 600+ well race boost you know, but you know I am sure I will be able to push over 550 and that will make me a very happy man.
Gear good to hear from you, so you think its worth to block it or not I mean in sure weight I will save maybe 3 grams.
Skit- should be around 450.
Old May 2, 2009 | 06:16 PM
  #24344
gear head's Avatar
I think it's worth it just to keep those 1000* temps out of the intake.
Old May 2, 2009 | 06:17 PM
  #24345
wesside's Avatar
I was hoping your weren't going to say take off the IM it's not really that bad I just have everything nicely ziptied and cleaned up right now
so you notice any power or intake temps lower? I assume yes, right?
